| Home > Help Needed / General Tech Chat > cometic compressed volume | |||||||
6th Aug, 2010 at 04:19:11pm
the cometic head gasket is stated as 030" i take it thats the gasket thickness, what would this be in cc? any ideas in working this out? Crystal Sound Audio said:
6th Aug, 2010 at 04:26:42pm
(Bore size of the gasket/2)^2 * PI * thickness will give you volume (all dims in cm to get cc)
Edited by Tom Fenton on 6th Aug, 2010.
6th Aug, 2010 at 04:30:32pm
0.03" is about 0.76mm so assuming the fire ring diameter is 74mm (I assume they size it for the biggest possible bore) then
Edited by Rod S on 6th Aug, 2010. Schrödinger's cat - so which one am I ??? |
6th Aug, 2010 at 04:30:52pm
Blimey Tom do i look that intelligent! Crystal Sound Audio said:
6th Aug, 2010 at 04:31:49pm
its 73mm Rod Crystal Sound Audio said:
6th Aug, 2010 at 04:33:09pm
Neil, there are two cometics, slightly different thicknesses and bores,
6th Aug, 2010 at 04:38:53pm
On 6th Aug, 2010 wolfie said:
its 73mm Rod For 73mm and 0.030" you get 3.2cc, sod all difference... Basically for 0.030" it's going to be a shade over 3cc whatever the fire ring diameter. Schrödinger's cat - so which one am I ??? |
6th Aug, 2010 at 04:42:40pm
Joe i could only find one on there site
6th Aug, 2010 at 04:47:27pm
theres the C4148-040 too, its listed under midget, thats what I was running as I'm at 73.5mm bores.
6th Aug, 2010 at 04:51:04pm
cool cheers joe Crystal Sound Audio said:
6th Aug, 2010 at 04:55:34pm
btw the 40 thou gasket will be about 4.3cc On 28th Aug, 2011 Kean said:
203 Posts Member #: 1734 Senior Member Lancaster |
6th Aug, 2010 at 06:49:37pm
cometic do different thickness gaskets depending on how many layers you want. a 3 layer (standard) is about 30 thou. I had a 5 layer on my old KAD head. that was about 55 thou. They seem to be able to do what ever you want. I needed it to bring my compression down a touch. |
