| Home > Help Needed / General Tech Chat > T3 turbo & boost gauge | |||||||
289 Posts Member #: 8160 Senior Member , mitcham, surrey, london, cr4 |
9th Aug, 2010 at 06:42:42pm
Hi there!
Nothing special! |
9th Aug, 2010 at 07:08:03pm
You will not see any boost until you drive it, revving it on the spot will not be enough. |
9th Aug, 2010 at 07:08:39pm
I carnt help with the turbo bits but your car wont make boost stood still.
9th Aug, 2010 at 07:09:11pm
beat me to it phil
9th Aug, 2010 at 07:45:00pm
9th Aug, 2010 at 07:58:22pm
thank you for reply!
Nothing special! |
9th Aug, 2010 at 08:04:30pm
it is very strange because before i was driving on 70mph with 5000 on the taho with my 998cc engine, and now it is 5.5 on 60mhp 1275 metro turbo engine and it struggle to run faster then 65mph :(
Edited by chominsh on 9th Aug, 2010. Nothing special! |
10th Aug, 2010 at 12:12:05am
Gasket on turbo outlet perhaps 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
10th Aug, 2010 at 09:09:22am
a rolling road will be able to help Yes i moved to the darkside |
10th Aug, 2010 at 09:20:39am
Where are you taking the signal for the boost gauge from?
In the 13's at last!.. Just |
10th Aug, 2010 at 10:17:54am
Sounds like you have a boost leak between the compressor outlet and the plenum chamber -- check all pipework and clips and then any gaskets on the compressor or plenum. |
10th Aug, 2010 at 12:26:49pm
On 10th Aug, 2010 theoneeyedlizard said:
Where are you taking the signal for the boost gauge from? I was using this sample: http://s750.photobucket.com/albums/xx141/c...=ben-h-1114.jpg Edited by chominsh on 10th Aug, 2010. Nothing special! |
10th Aug, 2010 at 12:34:58pm
Thank you!
Nothing special! |
10th Aug, 2010 at 04:00:13pm
Be very carefull do not change the elbow gasket take into a workshop and let them do it. My reason for saying this is two of those three bolts are more likely to shear than willingly come out. I have 4 T3 turbine housings on my bench that have suffered this failure.
Edited by Mr Joshua on 10th Aug, 2010. Own the day
10th Aug, 2010 at 05:28:56pm
Avon Bar sell a DK451 gasket set with all the gaskets in for a T3 and metro plenum etc. On 11th Feb, 2015 robert said:
20th Aug, 2010 at 03:30:23pm
thank you guys :) Nothing special! |
