Home > General Chat > Bollocks!!!!!!!!!!!!!!!!!!!!!!! But everything happens for a reason!
Mr Joshua
Member #: 1954
Luton Bedfordshire
Just went out to the car and found it like this.
I never liked the look of this screen as you could see where it looked like there were stress points in the screen and by the looks of it it has gone right along those lines, these are the vertical areas you can see in what's left of my front screen. The dark area in the centre of the screen is part of the shadow cast by the Budlia in my drive, I can see no impact marks and there are no stones in the vicinity. Bollocks!!!!!!!!!*frown*
Edited by Mr Joshua on 13th Aug, 2010.
Own the day
Typical failure of a toughened screen.
Coupe
Member #: 2178
Leyland, Lancs
The missus' Mini has what look like heat marks on the windscreen in the same pattern as your screen has left around the cracks - guess I'd best get it changed sharpish.
Ive seen those marks on a few screens...I think mine has them too? *surprised*
could have been worse - you could have been driving it at the time
minimad01
Member #: 8109
Suffolk
o dear makes me feel not so bad when i see that becuase i dropped mine an it dint stay in 1 piece like that the glass went everywhere sorry to hear about it mate
Drop A Gear An Floor It
Star Mag
Member #: 375
Leicestershire
Mine did this but i was doing about 70mph at the time!
Johnny
Member #: 6926
Accrington
never experienced or heard of this before now, lol bricking it now incase it goes on me haha
thats a bummer ....did someone use a small spring loaded center pop ?
Flame Red
Member #: 6267
Those lines can sometimes be seen in a toughened screen, probably explains the Triplex Zebrazone sticker. I don't think they are an indication it's about to fail. It's lucky it was laminated anyway.
i got a spare if you cant find one up your way
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
mine went in the dark at 45mph. i put it down to the cold, or a sudden temp change
Mr Joshua
Member #: 1954
Luton Bedfordshire
Could have been an interesting few seconds if that had hapened while I was driving. A friend says that was a Zonaly toughened screen which thank god you should not be able to have fitted, you may be able to buy one but a screen fitter should not supply and fit one (so I have been informed).
Have fitted a laminated one now which I pulled out of my other mini and it seems too small for the hole *Confused* Changed the rubber and still seems too small. What gives?
And if you have a zonal toughened screen fitted I would advise you change it or you could get a face full of glass!
Own the day
I've had issues in the past with differing sizes of screens- i think i went through 3 or 4 i had in the workshop before i got one to fit; interestingly it was the othewr way round for me
Mr Joshua
Member #: 1954
Luton Bedfordshire
Lads I have to say that I am glad this screen went because I found a much more serious issue.
I had to take the carpets out because of a little rain soak, and not to my surprise the sound deadening on the drivers side was wet. But the base of the sound deadening for the bulkhead was dripping, but only in that area.
On closer inspection I found a 3" tare in the floor pan around the drivers side subframe mount. If the screen had not gone I would not have found this until the winter strip. And seeing as the interior only went in a few weeks ago I can say with absolute certanty it was not there then. And there is no rust in the area its a tare through a clean sheet of material :(
Own the day
Does the tear look similar to this?
Common problem I believe
very lucky
Flame Red
Member #: 6267
I had the exact same thing on the subframe mounting points on both sides of the car. Althought it looked like a crack I assumed it had just rusted away like the majority of my car has. Usually cracks propagate from a weakness such as a hole but on my car it was in the middle under the mounting, which I did not expect to be an area experiencing enough strain to cause a crack. Alternatively is it due to cyclic loading of that area causing the metal to fatigue? I might be talking bollocks but I would be interested to know how I can avoid it cracking again.
