| Home > General Chat > well this sucks. thought it would have been lighter. | |||||||
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
13th Aug, 2010 at 07:38:06pm
i bought the MED flywheel +clutch+ back plate etc etc set up the light road one.
13th Aug, 2010 at 07:40:04pm
apparently 1kg of the fly is like 100kgs of the car - or something like that.
13th Aug, 2010 at 07:43:57pm
if you go to the minispares site and look for the verto lightweight flywheel it gives a step by step of how to calculate it, Yes i moved to the darkside |
13th Aug, 2010 at 08:22:42pm
The minispares version when available weighs 4kg.
13th Aug, 2010 at 10:53:25pm
On 13th Aug, 2010 apbellamy said:
apparently 1kg of the fly is like 100kgs of the car - or something like that. Did you get the verto or pre verto? So if fitting Carl's titanium bits, there would be no weight whatsoever?? On 13th Jul, 2012 Ben H said:
14th Aug, 2010 at 01:57:32am
apparently 1kg of the fly is like 100kgs of the car - or something like that. Did you get the verto or pre verto? it that is the case excellent... It's VERTO |
14th Aug, 2010 at 08:48:10am
what is the weight of a completely std flywheel, clutch? i have never weighed one,
14th Aug, 2010 at 09:05:10am
I cant remember now, lol I have since scrapped the standard flywheel. I did the same and compared the standard with the lightened, and as said above, its only 1 kg lighter. I also compared the whole shebang with an ultralight set up and the verto was considerably heavier. However, im not fussed as now at least I know the standard cast item is not ging to go pop at 8krpm On 26th Oct, 2004 TurboDave16v said:
14th Aug, 2010 at 07:43:38pm
It isnt the overall weight that matters. it's where that weight is located.
