Home > Technical Chat > turbo manifold, flowing query....
Rick.SPI
Member #: 8027
started flowing my turbo manifold last week. matched the ports to the gasket, then started on the turbo end of it. and started thinking.
bear with me. this isnt me telling this is me asking the experts a question.
well i was thinking that the wider its opened that end the slower the air will be coming out of it (presssure wise) so if you have it less opened it will have a higher air pressure spooling the turbo quicker at lower rpm. wheras when its opened more its a higher flow, but you will loose low end torque? so is it a trade of of what you want?
am i thinking along the right lines as i have opened mine a little but didnt want to go more untill i have the facts, heres a picture of what i have done... im assuming opening a litle will give me the best of both worlds or am i on the wrong track?
(edit: this is an aweful picture and makes it look a shambles but i can assure you its evener than it looks here lol)
thanks.
Edited by Rick.SPI on 15th Aug, 2010.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Because of how choked the mini exhaust system is all the porting you can do will only help to improve the flow rather than degrade it
Own the day
Rick.SPI
Member #: 8027
ok thankyou josh, so go full blown and knife edje the fins is the way forward.
Edited by Rick.SPI on 16th Aug, 2010.
Don't knife edge the fins. Think about it, what will happen?
maccamcvey
Member #: 6673
Worral Sheffield
big fat crack?
Melt?
Mr Joshua
Member #: 1954
Luton Bedfordshire
Major hot spots!
Own the day
You can thin them down, but leave a generous radius on them.
Rick.SPI
Member #: 8027
ok thankyou. much apreciated :) ive left a hell of a lot on at the moment. ill add a little radius and then leave it as it.
cheers.
yep, nice radius to reduce turbulance.
