| Home > Help Needed / General Tech Chat > Fitting an Electronic Speedo | |||||||
329 Posts Member #: 3193 Senior Member Torbay, Devon |
16th Aug, 2010 at 05:27:27pm
16th Aug, 2010 at 06:24:27pm
I've just been doing this myself. I basically just copied what mike had done and welded a beaker to the adjuster.
In the 13's at last!.. Just |
16th Aug, 2010 at 06:36:10pm
The easier way (and imo the better way) is to use the normal spedo cable. Put the end that normally connects to the spedo in a box and then fashion a spinny bit of that and mount the pickup on the side of the box. Easy. This way all the moving parts can be inside the car and the cable runs are much easier and not open to damage. http://www.twin-turbo.co.uk
16th Aug, 2010 at 06:58:46pm
well mine is super ghetto compared to everyone elses, araldited the magnet to the outside of the drum, then cable tied the pickup to an L shaped bracket off one of the backplate bolts. On 20th Oct, 2015 Tom Fenton said:
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
16th Aug, 2010 at 08:11:12pm
LOL at nick. |
16th Aug, 2010 at 11:03:27pm
maybe someone needs to fashion something that can connect onto where the speedo cable goes into the gearbox? like the box idea from BEN but without the cable, just a direct skrew on majig? or would it be a daft idea Edited by Johnny on 16th Aug, 2010. |
17th Aug, 2010 at 07:59:32am
On 16th Aug, 2010 Johnny said:
maybe someone needs to fashion something that can connect onto where the speedo cable goes into the gearbox? like the box idea from BEN but without the cable, just a direct skrew on majig? or would it be a daft idea http://www.twin-turbo.co.uk
17th Aug, 2010 at 08:02:35am
Why weld anything to the rear hub at all? - I have a wheel speed sensor picking up off of the end of the stud. On 5th Sep, 2011 Vegard said:
261 Posts Member #: 713 Senior Member Western Australia |
17th Aug, 2010 at 08:45:37am
maybe someone needs to fashion something that can connect onto where the speedo cable goes into the gearbox? like the box idea from BEN but without the cable, just a direct skrew on majig? or would it be a daft idea Has been done successfully as a homemade job: http://www.ausmini.com/forums/viewtopic.php?t=56384 or just use one off an MG gearbox (R65) On 24th Dec, 2008 Nic said:
eyh? im drubj but very confused##]#IU |
17th Aug, 2010 at 05:32:07pm
thats exactly what im after :) Cheers for the link |
17th Aug, 2010 at 10:24:54pm
I just made a bracket to hold the sensor and put a trigger on the pot joint - don't know if it works yet as I haven't driven the car. On 7th Oct, 2010 5haneJ said:
17th Aug, 2010 at 10:46:19pm
me too, wont give a good reading on hard cornering and spinning up etc, but im not fussed, its only to help me keep below 30 when the fuzz are following "Turbo's make torque, and torque makes fun"
17th Aug, 2010 at 10:48:55pm
heres a pic or 2 of mine, bit flimsey, but works fine "Turbo's make torque, and torque makes fun"
203 Posts Member #: 1734 Senior Member Lancaster |
17th Aug, 2010 at 11:07:34pm
my etb dash picks up off the nearside pot joint with a couple of magnets epoxied on. little alloy bracket with vr sensor bolted using 2 output cover bolts . Been using it like that for 3 years. passed 3 MOT's etc.
Edited by manifold on 17th Aug, 2010. |
18th Aug, 2010 at 09:48:12pm
Won't using the pot joint make the speedo inaccurate when that wheel loses traction, or when cornering? |
18th Aug, 2010 at 10:19:35pm
yes it probably does, but who cares that much? its near enough for road driving. I'm pretty sure a gearbox connected speedo will also be inaccurate when you lose traction? |
18th Aug, 2010 at 10:33:51pm
I guess it depends on what you are using the speed indication for. Just an electronic speedo and it probably doesn't matter. If it is part of a boost controller it may matter. |
lighter than a 5th wheel off a bicycle attached to the back of the car
