Home > Technical Chat > ball joints
mini6r4
Member #: 426
Maidstone, Kent
is it just me, or are these things a nightmare.
i spent about an hour and a half outside today with the sledge hammer, and broke the ball joint remover in the process. i ended up using a massive chisel we have been using to cut the paving slams.
surely there is an easier way!
Any ideas??
cheers
www.mini-roadster.741.com
Roadster conversion kits on the way!
you mean BJ splitter????
I use the 'fork' type, never have any real problems. Some of the fork types are useless however, too high a 'wedge angle' and the forks are too far apart. Far from ideal for a mini BJ.
sauber 200
Member #: 245
you have to undo the nut first.lol
i usually do them in about 30-45mins a side
like dave said using the correct mini frendly tools helps
Dangerous
Member #: 417
Hammer the forks on the splitter back together now'n again.
If all else fails get a trolley jack inbetween top and bottom arms for a bit more pressure
T3Tone
Member #: 252
Sunny suffolk
Have done really awkward ones on other cars before and gone at it full bore using loads a Wd40, bj splitter, big hammer and someone else with a big lever bar on bottom/top arm. Even if they havent been touched for years there's always a way of making them surrender!!
-MINI CLUBMAN 1380 TURBO-
Give the eye that the balljoint taper locates in a good pisser with a hammer. Works a treat usually but you need a good aim and also it needs to be a pisser and not a tap......
jukka
Member #: 60
Forgotten more than most ever know
I use a scissor type splitter. A heavy duty item that has never failed me.
evolotion
Member #: 83
Glasgow, Scotland
^^^ same. never had a ball joint that hasnt split after a few turns and a smack with the splitter on it.
Denis O'Brien.
i use a scissor splitter and a windy gun *happy* works without fail everytime.
mines a sykes pickavant splitter from hellfords.
