| Home > Help Needed / General Tech Chat > turbo engine won't start.HELP!!! | |||||||
![]() 384 Posts Member #: 4215 Senior Member |
19th Aug, 2010 at 04:16:39pm
hi everyone....
19th Aug, 2010 at 04:51:05pm
If the only things that you have changed are the fuel pipe and gasket then logic dictates it should be one of them. If the engine is getting fuel then can we assume the fuel connections to the regulator are unchanged from before ?.
19th Aug, 2010 at 05:09:07pm
hi mate...
19th Aug, 2010 at 05:11:29pm
you say you've changed the plugs - did you put the leads back on properly?
19th Aug, 2010 at 07:59:39pm
double check that you have put the pipes on the correct inlets on the carb. and make sure petrol is getting into the engine. i check this by cleaning the plugs, turning over the engine, then taking on out to smell it/look at it to check for fuel? if there is fuel, it may be gone off fuel? or its probably a problem with the electrics? make sure the engine has a good earth to the body and make sure its a good spark. check the colour of the spark on the plug, ie orange or blue? |
19th Aug, 2010 at 10:26:44pm
hi guys...
20th Aug, 2010 at 12:36:14am
I think that you could have messed with something,
20th Aug, 2010 at 11:28:27am
i have checked everything i did... and i didnt do a lot, like i said only messed with manifold:( dam mini.... |
20th Aug, 2010 at 11:44:53am
You may have a carb issue probably dirt in the needle valve or jet. take it of get it cleaned set the jet level with the bridge and start from scratch. recheck your fuel lines, they can colapse internally which is hard to spot unless you know what to look for.
Own the day
20th Aug, 2010 at 12:44:21pm
Have you taken the inlet manifold off yet to see if the gasket IS faulty or leaking ?. |
30th Aug, 2010 at 05:10:00pm
hi guys...
Edited by c2_mad on 30th Aug, 2010. |
30th Aug, 2010 at 08:52:38pm
For the future, if it doesn't start it can be one of only three main things;
![]() 334 Posts Member #: 7169 Gobshite that posts wank videos. Somerset, UK |
30th Aug, 2010 at 09:17:45pm
On 30th Aug, 2010 c2_mad said:
hi guys... thanks for all the comments, i finally got it started... turned out, we had swapped the fuel lines when i disconected them, we then put them back on right again, but what we didnt know is that while they were swapped, and we were trying to start the engine it filled the whole induction system, intercooler pipes and intercooler, with petrol so no air could get through so it would not start... any way thanks for all the help guys...i really apreciate it.... i do have a couple of questions tho... 1. i need a cluth kit for my mini, what do you recomend, i want something good 2. what radiator do you recomend, as i dont know which is better, quad core or dual core, i'm temped to think 4 is better than 2... 3. where do you connect the vacum pipe that connects to the wastegate.... thanks in advance.. Dual core is better, and i would start a new topic for the other two Gaball said:
Motorsport Engineering Student Project Car 1293 Turbo Mini (on a student budget) On 7th Oct, 2010 apbellamy said:
Carbon but plug? |
31st Aug, 2010 at 03:45:31am
thanks mate..
fab:1 gearbox:0
