Home > General Chat > Did a Rack today
What a ball ache... Don't want to do another soon.
I did a duck, it was a bugger.
was it a hefty top rack?
Thats tonight nic..... :)
i just did a rack of lamb,
mmmm lamb
maccamcvey
Member #: 6673
Worral Sheffield
i need to do one thanks for putting me off
Carl S
Member #: 1761
Stalker
I've changed a rack, it's not that hard!
Especially with no engine or front frame in place *happy*
unfortunatly they are a pita,
undo all engine tie rods,
undo brake pipe to subframe, drop exhaust,
remove carb (iirc)
remove shocks
undo subrame mounts and drop subby 2-3"
piss about with the rack for a while,
put every thing back...
Edited by Joe C on 22nd Aug, 2010.
At least it was A Rack not Iraq
remove clutch slave cylinder but it you have the long goodridge hose there is enough space
remove steering column..
I had to remove the remote gear change too.
oh on another note, you might as well get new column bushes. I did the top and bottom and get a new rack pinion seal...
Wayne said:
A gun rack... a gun rack. I don't even own *a* gun, let alone many guns that would necessitate an entire rack
Mr Joshua
Member #: 1954
Luton Bedfordshire
Changing mine tomorrow :cool:
Own the day
Honey Horne: I'm goning to be frank.
Garth: OK. Can I still be Garth?
Wayne: No way!
Garth: Way!
Mr Joshua
Member #: 1954
Luton Bedfordshire
Its tomoroow and its raining :(
Own the day
Carl S
Member #: 1761
Stalker
You'l get a wet rack then *happy*
Nothing better!
now thats funny :)
Ah your problem is it's a standard BL item, i have no such problems on my cars, lol
carl
1293 sprite
Member #: 5449
Melton Mowbray
I did mine in about an hour, dropped the rear mounts and tower bolts, then got a great big scaffold tube, undid the u bolts and out it came. Then again I was rushing to get it back on the road after snapping the rack, shattered the top ball joint, bent the bottom arm and tie bar, bent the steering arm, popped the driveshaft out of the pot joint and cracked both front alloys (didn't quite make it round the roundabout lol)
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
evolotion
Member #: 83
Glasgow, Scotland
carl
do you do upgraded racks? or you referring to the frames:)
Denis O'Brien.
that sounds like quite a roundabout *happy*
carl
frames
carl
mm a Ti hydro frame just dont have the 1300
