| Home > General Chat > how to change from points to electronic ignition | |||||||
88 Posts Member #: 7788 Advanced Member bradford west yorkshire |
24th Aug, 2010 at 11:17:16pm
can anyone help i am thinking about doing away with the points on my 1994 mini rio 1275 i have been looking at some kits but dont understand the requierments it says i need to have a negative earth ,non ballast points type coil and a points type coil with more than 1.5 ohm resistance can anyone help me on this thanks |
24th Aug, 2010 at 11:20:26pm
24th Aug, 2010 at 11:22:42pm
dont think so how would i beable to tell |
25th Aug, 2010 at 01:56:25am
25th Aug, 2010 at 05:28:09am
Are there wires coming out the side of the dizzi? Own the day
25th Aug, 2010 at 07:38:46am
doesnt a 1994 1275 have electronic ignition anyway? Yes i moved to the darkside |
25th Aug, 2010 at 08:24:52am
hi no there is just 1 black wire that comes out the side of the dizzy and joshua i thought it would be rlectronic but i am no convinced it is the original engine the number identification tag has also been played with so ii am having trouble identifing the engine all i know is its a 1275 lol |
25th Aug, 2010 at 08:38:52am
Put a picture up and we can try and help you work out what you have On 11th Feb, 2015 robert said:
25th Aug, 2010 at 09:04:21am
a 1994 Rio is carbie and will already have electronic ignition, as long as it is the original engine and distributor On 26th Oct, 2004 TurboDave16v said:
25th Aug, 2010 at 06:49:51pm
well if thats the case it is not the original engine then as in definatly has points |
26th Aug, 2010 at 12:53:08am
Not electonic per say. you shoud have two wires coming out of the Dizzy with module mounted remotly. There should be a box of tricks to go with this item.
On 25th Aug, 2010 johnrg said:
hi no there is just 1 black wire that comes out the side of the dizzy and joshua i thought it would be rlectronic but i am no convinced it is the original engine the number identification tag has also been played with so ii am having trouble identifing the engine all i know is its a 1275 lol Edited by Mr Joshua on 26th Aug, 2010. Own the day
26th Aug, 2010 at 11:27:14am
yes i took the dizzy cap off and it defo has points only 1 black wire comes out of it |
27th Aug, 2010 at 12:26:49pm
If you want one and anyone can find out what curve this motor is supposed to have I have several dizzys that may suite your motor. Own the day
