| Home > Help Needed / General Tech Chat > minispeed turbo camshaft | |||||||
71 Posts Member #: 5754 Advanced Member Bridport Dorset |
29th Aug, 2010 at 02:29:04pm
hi i need some opinions on camshaft choice has anyone used the minispeed cam or the MED/piper turbo cam |
![]() 334 Posts Member #: 7169 Gobshite that posts wank videos. Somerset, UK |
29th Aug, 2010 at 09:08:05pm
Avonbar phase 2 is highly rated but a bit pricey these days Gaball said:
Motorsport Engineering Student Project Car 1293 Turbo Mini (on a student budget) On 7th Oct, 2010 apbellamy said:
Carbon but plug? |
1st Sep, 2010 at 12:21:11pm
I have got the minispeed cam in mine this year and seems to be ok Although I dont know wat the lobe figures and angles are as they wont tell me so I will reserve judgement untill I fit my MG cam and give that a run.
Own the day
1st Sep, 2010 at 10:14:37pm
I'm going to be trying the RE13T,
Edited by Joe C on 1st Sep, 2010. On 28th Aug, 2011 Kean said:
1st Sep, 2010 at 10:40:08pm
When is Robert going to start selling his spunky grind? In the 13's at last!.. Just |
1st Sep, 2010 at 10:41:27pm
Eeuuuwwww!
2nd Sep, 2010 at 06:20:00am
After trying some cams (274sp, 274i, phase two...)
2nd Sep, 2010 at 10:24:54am
well said Own the day
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
2nd Sep, 2010 at 09:02:29pm
Anybody got an engine running with the megadyne 266 in ?
2nd Sep, 2010 at 11:25:15pm
i ran one in my first lump seemed good, benross is running one in he apparent monster. On 28th Aug, 2011 Kean said:
3rd Sep, 2010 at 05:02:50am
the 266 is certainly good,
3rd Sep, 2010 at 06:15:58pm
the kent 266 is great!
3rd Sep, 2010 at 06:49:14pm
I run a 266
3rd Sep, 2010 at 07:49:59pm
a little bit of correction, 183 bananas please :)
On 3rd Sep, 2010 BENROSS said:
the kent 266 is great! T3tony runs one on his 1380 it made 183 bhp at 13psi on hybrid turbo of some sort the phase 2 cam for big numbers!! all the way! dont discount the kent MD 274sports injection with power band 1000 rpm to 6000. figures in short cam lift 0.285" inlet 0.281" ex, 248 deg inlet 274 deg exhaust |
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
3rd Sep, 2010 at 09:57:27pm
Whats the MED 'T3' cam like? or is it the same as the avonbar 'Phase 2'? On 25th Sep, 2009 mini13 said:
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
3rd Sep, 2010 at 10:02:25pm
the kent 266 is great! T3tony runs one on his 1380 it made 183 bhp at 13psi on hybrid turbo of some sort the phase 2 cam for big numbers!! all the way! dont discount the kent MD 274sports injection with power band 1000 rpm to 6000. figures in short cam lift 0.285" inlet 0.281" ex, 248 deg inlet 274 deg exhaust Mine may have been ancient, welded dizy, laggy turbo etc, but around 97/98 I put the SW5 in, which was a bit better than the old MG cam I had in very torquey right from 1000rpm, and would pull very strongly to over 7k. No idea of any of its stats tho 9.85 @ 145mph
3rd Sep, 2010 at 10:23:53pm
its the same according to my info
On 3rd Sep, 2010 1293 sprite said:
Whats the MED 'T3' cam like? or is it the same as the avonbar 'Phase 2'? On 28th Aug, 2011 Kean said:
4th Sep, 2010 at 01:36:24pm
Did a little looking a while back and the MG, Kent 266 and SW05 were damned near identical in there profiles Mr Dodd did a stirling post on cams on another forum the link is on here (as I put it on) and even the cam design I derrived for mine was yet again near identical to the above three. I have seen no figures for the phase2 cams or some of the others mentioned but there seems to be very little room to manouver around what is the best cam profile for a turbo.
Own the day
4th Sep, 2010 at 08:43:39pm
On 3rd Sep, 2010 Joe C said:
its the same according to my info On 3rd Sep, 2010 1293 sprite said: Whats the MED 'T3' cam like? or is it the same as the avonbar 'Phase 2'? Great thanks for that :) On 25th Sep, 2009 mini13 said:
