Home > Help Needed / General Tech Chat > just a quick question about compression ratio sorry!
blister
Member #: 2590
Croydon
well my engine being a metro 1275 engine 12hA83AA
i am just trying to work out what the compression ratio is all the engine is standard except the head has got 22cc chambers
i cant seem to find any spec of engine just parts of it in the haynes manual
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
What's the bore and stroke again ill do the maths quick
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
Gaball
Member #: 7169
Somerset, UK
It's
(1/2 BORE x pi squared) x STROKE
Divide that by the combustion chamber volume and that's it assuming the pistons are flush with dexk
Carbon but plug?
blister
Member #: 2590
Croydon
everything is standard in the block for the metro engine
The problem is that there are plenty of different standards and with out measureing you are just guessing. Look at roberts Vauxhall engine, if he'd have just assumed all standard he'd have melted something.
You need to measure. Firstly, if the pistond have markings, it should be easy to find what cc they have in the dish, ring land and gasket can be estimated.
The only other thing you need is the piston to deck measurement.
On 29th Aug, 2010 Gaball said:
It's
Wrong on several counts.
(1/2 BORE squared x pi) x STROKE
Divide that by the combustion chamber volume, then add 1.
blister
Member #: 2590
Croydon
right i have done some measuring and i have come up with 10.25cr
piston dish : 6.0cc
ring land volume : 0.78cc
gasket ; 4.2cc (bk450)
piston deck clearance: 0.99cc
head : 22.5cc
bore; 70.61mm
stroke: 81.28mm
after reading around on forums i have come to the assumption that i need a 8.1cr so am i right to think that a 3cc decompression plate (temp) and another head gasket that will take me down to 8.3 compression is this ok?
i will be using megajolt and 10psi from a eaton 45
By my clac's it's 10.77:1 as the BK450 is is 3.8cc.
with an extra gasket and a 3cc decomp plate I make it 9:1.
Gaball
Member #: 7169
Somerset, UK
Yep sorry got my pi's r's and sqaures mixed up!
and where's the plus one? is that a constant Paul?
i have never been taught this so just wondering?
It's
Carbon but plug?
blister
Member #: 2590
Croydon
ah great so i need a 6cc decompression plate and all should be well
Because it's actually (swept volume + combustion chamber volume) all divided by combustion chamber volume.
Swept volume is the pi*r^2*stroke or ((pi*d^2)/4 )* stroke.
So if you say the swept volume (all the pi bit) is SV and combustion chamber volume is CV, just to make it look prettier,
CR = (SV+CV)/CV
which you can rewrite as
CR= SV/CV + CV/CV
Or
CR = (SV/CV) +1
Personally I just use a spreadsheet :)
EDIT - obviously in my simplified version, combustion chamber volume is the total combustion chamber volume, ie, the actual chamber in the head + piston dish + ring land volume + below deck volume + gasket volume.
Another good reason to use a spreadsheet, so nothing is missed.
Edited by Rod S on 1st Sep, 2010.
Dont waste your time, just get a head with 28cc chambers.
28cc head only gives him 9:1, he needs to look at his piston choice too.
blister
Member #: 2590
Croydon
cannot change pistons as that would mean taking the block apart and i dont really want to modify the head any more as if i decide to run N/A i would then have to have the head skimmed lots to bring the ratio up
so i am after using a decom plate i have useds a decom plate on my t2 1275 and that never had any trouble running 12psi and i covered 600ish miles
Ben H
Member #: 184
Melton Mowbray, Pie Country
What sort of boost are you thinking of running if you are looking for 8:1 CR?
http://www.twin-turbo.co.uk
I was recommedned 8:1 for my suck through charger setup running 12psi
Gaball
Member #: 7169
Somerset, UK
Oh so its just a rearangement of the CR= SV+CV all over CV equation :) I get it now
Just for the remember to Square my R's not my Pi's :$
CR = (SV+CV)/CV
CR= SV/CV + CV/CV
Or
CR = (SV/CV) +1
Carbon but plug?
blister
Member #: 2590
Croydon
was after running the 10psi which means running the smaller pulley but would not mind getting it running with the standard pulleys which i believe should be 6-7 psi
blister
Member #: 2590
Croydon
