| Home > Help Needed / General Tech Chat > mini handbrake adjustment | |||||||
88 Posts Member #: 7788 Advanced Member bradford west yorkshire |
29th Aug, 2010 at 08:05:22pm
i have put new handbrake cables on my mini rio front and back also replaced the drums the shoes have 5mm left on them so didnt replace them i have adjusted the handbrake and it pulls tight but just dosent lock up the rear wheels i have sanded the shoes and drums as to make them rough but still the same it did work until the front cable snapped but since then i have put new backplates ,new cylinders,new drums ,new cables i am out of things to try has anybody had any simmilar sort of problem if so what was the cure thanks john |
29th Aug, 2010 at 09:01:20pm
First off you need to adjust the shoes on the backplate first of all, then and only then do you adjust the cable.
29th Aug, 2010 at 10:26:26pm
i adjusted at the backplate untill wheel locked up then turned back untill wheel spun freely on both sides then adjusted in the car the leaver only comes up to 3 notches but i can still push the car when it is fully applied i am unable to drive it as i have no mot i am just preppin it for the mot but having lots of problems this is just 1 of many all which i have fixed apart from this 1 |
29th Aug, 2010 at 10:38:33pm
I have seen the hand brake mechanism bottom out before, so the handbrake can be adjusted but the shoes wont press against the drum properly.
