Home > Help Needed / General Tech Chat > Last question i promise - clutch slave holding plate
jamesfawcett
Member #: 218
Bingley, West Yorkshire
sorry my last question this week, just another problem i had last night was my car drank all its clutch fluid, this is the 2nd clutch slave since putting the engine in, and i couldnt find the leak anywhere. I just noticed its coming from the clutch slave, and i think its because of how much the plate that holds it is flexing!!!
Its a short arm on the "china-mans-hat" with a plate coming off the top under the engine stabiliser. The plate it held on at the top by two bolts which are really tight, i think they are 14mm. there is a holdejust above where the arm comes out of the "china-mans-hat", its only tiny but im wondering if its threaded to hold a bolt or similar from the plate.
Im searching google images simultaniously right now for 4pot flange pics, brake slave plates and pics of carb springs!!!
http://www.manchester-minis.cwc.net/techni...bleshooter1.htm
It's becuase the slave is fooked...
Cheap and nasty parts sold by mini specialists probably...
Buy a pukka (genuine) one from Rover, minispares, Moss, etc - or from Halfords (?) and keep your reciept to claim your 12 months warranty!
D
jamesfawcett
Member #: 218
ok, that bit is missing on mine! I guess that bolts to the hole on the clutch slave bracket! Mine is far out of line!
jamesfawcett
Member #: 218
Does anyone have a spare one i can buy? I dont have any bits for short arm clutches anywhere :(
jamesfawcett
Member #: 218
will order one at halfrauds thats a good idea, btw we are doing trade cards now to people who work at garages *wink* They beat any trade price guarenteed, including andrew pages, motaquip etc! batteries, clutches everything! handy for getting brakes and stuff on sundays, if anyone wants a trade card let me know
Edited by jamesfawcett on 15th Feb, 2005.
Do you have a B&Q, plumbers merchants, anything near you??? Just buy a length of steel tube, cut it to length, and bob's your uncle.
Before you ask the length... I don't know - just gauge it off the pic.
another thought - you could probably just use a few 8mm / 5/16 nuts (the 13mm spanner sized ones) and a few washers - saves on buying a length of tube!
I'm guessing you don't have a bolt either?
You need a 1/4"UNF bolt - you're best judging on the length...
I'd be concerned why it's not there though - maybe the thread is stripped out of the alloy housing??? Best to take off the slave, then the plate and check the thread out with a little mirror and a torch. If it looks ok, it probably is.
Fit the plate first (without the slave) - it's easier if you fit the 1/4" bolt and spacer first (but leave loose) - AFTER you've checked the length of the tube / packing washers/nuts - then fit the 3/8" bolts, then tighten it all up.
oh, this would have goosed the slave through side-loading the piston!*wink*
Edited by turbodave16v on 15th Feb, 2005.
Bend it straight and bolt it up should get you going for now.....
pot_dan
Member #: 326
bradford, west yorks
yup dave that is what has happend, he apeard at my house last night asking for clutch fluid as he los all his and we saw what had happend the rod fromt he slave cylinder is at a verry poor angle and you can feel the its damp there but not physicly dripping. new slave cylinder needed deffo, unless you can get service kits or something?
Dan
http://turbominis.co.uk/car/105/
jamesfawcett
Member #: 218
ill just get a new one there only about ?25 i think. At least i will stop going through them now! I need to get a bolt with the right thread for the clutch housing next 1/4"UNF like dave says :)
You might find the bolt that a standard seat pivots on will be long enough to do the trick? And definately 1/4" UNF.
jamesfawcett
Member #: 218
Just been to the bolt distributors, think ive annoyed them iwth my 50p orders now! anyway i got one suitable and gonna go have a go now *happy*
jamesfawcett
Member #: 218
PERFECT! No more play in the bracket, its very solid. The clutch slave seems to be ok, im going to try and make it last until i buy a braided clutch hose off iain and then change the slave too when i have a bit more cash *happy* thankyou everybody its really refined now, feels like it did in the metro again!
Nick
Member #: 154
Midlands
dude, you cant put refined and metro in the same sentence......lol *happy*
jamesfawcett
Member #: 218
lol! The metro turbos ive had drive so nice though, its just not like an a series! and then you bolt it in a mini and it just chugs about!!!
nutter driver
Member #: 47
Not very sunny swanage
how do we get these trade cards then?
