Home > Help Needed / General Tech Chat > O/T VW Lupo: Oil in air filter?
longy
Member #: 2727
Bicester
Hey guys, just went to change my air filter on the Lupo and found it in this state:
Im a bit puzzled, the engine runs fine, maybe a little lumpy at idle and no smoke. any suggestions?
Chris
1972 998 TURBO SLEEPER
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Blocked breather would be the most obvious problem. If one side is blocked it causes excessive crankcase pressure and oil then spits up through the remaining breather. I've replaced breather canisters before but not on that engine
On 30th Apr, 2010 Rod S said:
Gary's description is best
longy
Member #: 2727
Bicester
Cheers gary, i checked the breather that feeds into the air box and there was hardly any signs of oil.
Yeh, breathers.
I found this on the wifes Arosa, and the breathers were solid with Mayo.
longy
Member #: 2727
Bicester
cheers guys ill have a closer look at the breather system tomorrow.
Billys Bits
Member #: 8949
surrey
i get this on my lupo never thought it would be the breathers never really bother thinking to be honest
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
just time to change your air filter, it certainly was restricting, then making more vaccum suck to breathers. chnage it for vw one, and see in some miles
longy
Member #: 2727
Bicester
cheers guys
