Home > Show Us Yours! > helical drops revue on 190 bhp +
well , looking for the noise in my transmission , i started with the drop gears, and so hoicked off the side case ..
as you can see ,they look pretty much just as they were a few years ago when they went together ! most interesting .
now,bhp and torque wise ,what have they had to put up with ?
well, its had 188 bhp and 184 lbs ft at the shootout ,16 psi boost .
its since run a steady 19.5 psi at avon ,and peaked on the gearchange at 23 psi boost .(and thats with a nice flow of air through the ic ,something it did not have at the rr )
so i think its safe to say over 200 lbs/ft and 200 bhp ?
regards
robert (still looking for the noise ;()
Edited by robert on 5th Sep, 2010.
What endfloat have the idlers been assembled with?
Edited by minimole23 on 5th Sep, 2010.
cant remember moley , id imagine whatever is in the book for them .it was 1998 when i built it .lol
I ran my std drops for some 60k and never had any problems.
What exactly was the noise like, and when did it occur ?
What clutch ?
Ha fair enough.
I was just looking for reasons why yours has held together whereas so many others have failed.
12 years is bloody good going not have had to rip the engine apart for a rebuild. (by a previous thread the gearbox clearly ripped itself apart so doesn't count!)
Is your transfer case cracked where the idler gear sits? Looks like it's got a spider sat in it...
What clutch ?
on this thread steve ,
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=378838
clutch is a verto .
Thats impressive Robert. How many miles have they seen?
I've said it before, the earlier smaller idler bearings were prone to failure, and drop gears have built up a reputation from failures of these.
The later, larger, idler bearings are much better. I have found them totally reliable.
EricsAmerica
Member #: 7891
Annapolis, MD USA
Thanks for the info....very good to know as my straight drops just about send me insane after 20 minutes or so....
I did munch all of the teeth from my laygear recently, so I installed the clubman straight set, but I may switch back to the helical drops given your info as I am only N/A 1380 right now with boost in the works...
PS....Vegard, you don't have to say I told you so! *Yes*
Eric
my pics.... http://www.fototime.com/inv/7AAF37CF3EFA956
What clutch ?
clutch is a verto .
I once had the strangest squelching sort of noise on mine. I took it all apart thinking the gearbox was screwed like you....but to no avail.
Although the noise occurred with the engine running as opposed to on switch off.
Check the verto-boss bolts are tight.
good point steve ,ill check them tomorrow.
very intresting robert, iam i correct in saying you ran the helical drops with a SC gearset ?
the milage would be intresting ...... ?
is there any wear on the 1st motion shaft bearing ? and the gear and head set ?
yes steve , the staight cut clubman set from min-its , trannex i think .
no wear on the bearings i can find . mileage id guess at around 5k miles in two years .mostly at 175 bhp ,but raced at well over 190 bhp .
well pleased with your results robert top man.
one thing is that no more SC drps screaming if you dont want it
PaulH
Member #: 2340
Dublin Ireland
Robert It is fantastic that you have final put an end to this Drop Gear Myth I have been runing a set of hel's in a customers Racer for 3 years at 120 HP and well over the 100 in torque and like you we have never seen a problem,
well done that man.
On 17th Feb, 2009 Rob H said:
Robert, its brilliant news and shocked most people i think , but i do think i have found the reason why they have lasted ??
Your just not driving it hard enough. lol
Rick
its so true lol
I agree.....
Combe this year???
bit more info..
cleaned up the gears ,here are some pictures of them ,they look fine ..
found i didnt have the right washers to do the end float on the idler ,so selected another idler that was .3mm thicker ,,
but have a look..
it doesnt look as well finished ,and the teeth on the turbo one are rounded on the tops ,,was there a better idler fitted to the turbo cars ?
notice its machined on the sides not rough cast like the other ..
Rick
As I say. I ran mine for some 60k over the 2-3 years I daily drove my car back in 94-97
That was with 21psi boost, and it really did get abused something shocking.....as you can imagine with something like that when you're around 18 and dumb.
I went through several std gearsets, one straight cut 2nd gear, several cases, a couple of diffs many head gaskets, couple of pistons, and various other items.
But always with standard A+ drops.
allegedly there was something about the MPI drops that was uprated.
Yes, they used the better Torrington roller bearing. Looks like Robert has them in there.
this is definately an original 1987 turbo one .( i mean the gear,not the bearing )
Edited by robert on 8th Sep, 2010.
thats it!
I remember the article where Calver was banging on about it now...
