| Home > Show Us Yours! > Castle combe yesterday | |||||||
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
12th Sep, 2010 at 07:46:07pm
took the mini round combe yesterday for its first real track outing, great fun but encountered a few things that need sorting.. arch was rubbing quite a bit and made a nice groove in the tyre! and the oil temp went up to 120 deg c, so an oil cooler is needed.
Edited by Monkeh on 12th Sep, 2010. |
12th Sep, 2010 at 10:13:22pm
Tyre rubbing and oil cooler are teething problems and easy to sort.
12th Sep, 2010 at 10:16:32pm
also look at the corner weights,
![]() 85 Posts Member #: 3600 Advanced Member Gateshead |
12th Sep, 2010 at 11:07:13pm
What camera are you using taped to the front - nice clear pictures |
12th Sep, 2010 at 11:23:51pm
looks like a very quick mini mate!
My build thread..
13th Sep, 2010 at 06:12:36am
as Tom said , rear toe in, a little bit of front caster, for steering control.
13th Sep, 2010 at 08:33:34am
Looks to me like its the front that needs stability, start there first.
Edited by cossierick on 13th Sep, 2010. |
13th Sep, 2010 at 10:18:52am
thanks for the advice.
Edited by Monkeh on 13th Sep, 2010. |
13th Sep, 2010 at 10:33:56am
On 12th Sep, 2010 svrdaniels said:
What camera are you using taped to the front - nice clear pictures search for key fob camera on ebay, theyre about £10 On 12th Sep, 2010 JT said:
looks like a very quick mini mate! what spec is it if you dont mind me asking? cheers josh all the usual good bits, 1293cc, 20psi 173hp |
13th Sep, 2010 at 06:43:06pm
What off-set wheels do you have?
13th Sep, 2010 at 07:28:59pm
mid range boost control - isn't that you right foot? I run a supercharger and I don't care the TB is on the wrong side.
13th Sep, 2010 at 07:48:07pm
On 13th Sep, 2010 Monkeh said:
thanks for the advice. at the 5:00 min mark you can see the car was very twitchy around that slight bend and the back end stepped out a tad. i dont get why its so bad, the geometry and corner weights have just been set up. Front tow - parallel camber - 1 degree castor - 5 degrees Rear tow - 1mm tow in camber - half degree rear ARB fitted too. could the ATB diff be making matters worse? i thought it felt good on the corners but was a nightmare on boost if you have set the toe parallel i would now turn one end of the rack into the TRE 1/2 a turn, this will toe the wheels out slightly, try it to see if its any better, if it is, then turn it another 1/2 at a time untill your happy, carl |
13th Sep, 2010 at 09:27:00pm
im running early type 10" mambas, not sure what offset they are. ive got a pair of cooper s reverse rims which are slightly less offset, might be worth trying them on the front?
14th Sep, 2010 at 06:41:37am
14th Sep, 2010 at 11:32:12am
Yep its wants to be toe in for more stability front and rear, toe out on the front will make it turn in better but less stable in a straight line.
14th Sep, 2010 at 01:17:34pm
Toe in at the rear sounds strange if you want to go fast around a track. What you're experiencing is down to the front end.
14th Sep, 2010 at 09:08:31pm
im running early type 10" mambas, not sure what offset they are. ive got a pair of cooper s reverse rims which are slightly less offset, might be worth trying them on the front? carl, i was under the impression that tow out on the front would reduce stabillity? just had a look at the DON going around castle combe, doesnt seem to do what mine does. what diff is in it? do you have any rubber in your front suspension,? if the answer is jes you will never cure your problem with a high torque turbo motor,if the answer is no do what i said and see if it works, FORGET TOE IN ON THE FRONTunless you like hitting things carl |
14th Sep, 2010 at 09:22:53pm
On 12th Sep, 2010 Monkeh said:
a few things that need sorting.. arch was rubbing quite a bit and made a nice groove in the tyre! you should be used to that ! id say wheel offset as well , i run a little toe in on the front , it basically makes my turn in a little less sharp ,but track straighter on power , using a 4 pin diff .on a lsd it could be different . robert Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
