Home > Help Needed / General Tech Chat > questions
blister
Member #: 2590
Croydon
right couple of questions
am i right in thinking that the boost gauge take off is after the supercharger? ie on the manifold and do i have to have a pipe coming off both branches of the manifold to give a equal flow from each?
also i have a weber fitted to my supercharger before i start it up shall i put stronger fueled jets in:?
blow through/ suck through?
does the boost gauge read vacuum aswell?
blister
Member #: 2590
Croydon
yeah boost gauges has minus as well as positive
and the set up is suck through
ok it wants to be on the inlet manifold after the supercharger then
blister
Member #: 2590
Croydon
will it be a t piuece from each branch job or shall i just do it right underneath the charger hole
Everything after the SC will be at the same pressure, so one signal is all that's needed.
blister
Member #: 2590
Croydon
so where i put the yellow dot will fine
http://s370.photobucket.com/albums/oo146/b...=Untitled-1.png
Edited by blister on 16th Sep, 2010.
Fine
Assuming the picture is of the manifold upside down, I personally wouldn't put it at the very bottom in case any fuel vapour that condenses after the engine is stopped runs into it and then gets pushed up to your gauge.
Having it in the middle is fine as already said but try and make sure it isn't pointing straight down.
Good pint Rod. sticking it on one side would be fine
On 16th Sep, 2010 wil_h said:
Good pint Rod.
Beer on the brain Wil?
DAMN Double shot.
Edited by John on 16th Sep, 2010.
blister
Member #: 2590
Croydon
thanks fellas i will put it where the take off would be as you can see in the photo
