Home > Help Needed / General Tech Chat > Splitting the Megajolt feed?
Johnny
Member #: 6926
Accrington
Hello, im in desperate need to plumb in all my stuff into the inlet manifold i was wondering if i could split the feed pipe to the MJ unit twice? and it not affect anything in any way?
I have 2 T-pieces one is a splitter and the other one is too but one of the outlet feeds is a pin prick hole (which i used for my boost gauge, and that worked fine when i had the engine running before). the other goes to the apexi DV which i am led to believe uses boost to open the valve so this too doesnt need much to operate it.
heres a pic to help. im just asking if its possible for me to do what i have layed out in the pic?
Thank you, Johnny.
http://i185.photobucket.com/albums/x28/joh...mjdvtakeoff.jpg
No problem with that, I've run it like that on a number of my cars.
Johnny
Member #: 6926
Accrington
thank you, thats awesome, good to know its being tried and tested then :) back to work now, getting it all running for coombe (then germany)
Edited by Johnny on 17th Sep, 2010.
We run DV, Gauge & MJLJ from one feed tapped into the flat bit on top of manifold. No problems so far. However I would prefer to split the DV from the other two.
tadge44
Member #: 2500
Buckinghamshire
Thats because the DV works off the vacuum, not the boost pressure.
