Home > How To > turbo carb
terryg
Member #: 9065
weston-super-pier
hi can i make a HIF44 CARB into turbo carb
sim_ou_nao
Member #: 114
Porto/Portugal
Yes... you need to use a special tool... the search button *Idea*
Pedro Silva
lol good one.
joslin
Member #: 8584
I know the post is a year old, but what about converting weber side draft for turbo blow through use?
You also need to use the special tool search button.
sim_ou_nao
Member #: 114
Porto/Portugal
Pedro Silva
nutter driver
Member #: 47
Not very sunny swanage
Quick question on this, 3-4-5 which need to be blocked. Are people still doing this (im assuming so)? If so, how? im thinking that the best way would be to drill and tap the carb for grub screws fitted with a little blob of locktite unless anyone has a better way??
Short piece of hose and a bung in the open end of the hose?
No i didnt
You can pull the brass barbs out quite easily
Tap away iirc the holes are already prefect size for m8?
nutter driver
Member #: 47
This is what i did when i orginally screwed the car together, but as im about to rebuild the carb (following the excellent thread up there ^^ ) i kind of thought it might be worth doing something a bit more permanent while its all in pieces and I can clean the swarf out nice and easily etc. Obviously this might have been useful information for me to have put in my last post....... lol....
evad1980
Member #: 10165
Stansted, Essex
Chaps... In the diagram above, no.4, anti-run-on valve connection... it says to block off or it won't run on boost.
However, on my set up, I have a rubber hose that runs from there round to the turbo (the tee-piece with the other end going to the actuator)... this was done by Neil when I took it to the rolling road.
Now, I'm wondering if maybe I put this back on the wrong pipe when I had the manifold and carb off since, after reading the above post?
Is that a correct setup?
I hope my problem is as easy as that to fix... it would make sense as it was fine on the rolling road.. and it seems my problem is when coming on boost..
You're ok. Yes it says to block it, but I guess it should have said to block it or use for tee-piece trick (same for # 7)...
Edited by turbodave16v on 12th Oct, 2017.
evad1980
Member #: 10165
Stansted, Essex
So does that act the same as taking a 'tee' out of the pipe normally used for the tee piece trick (plenum to regulator)?
So in essence... I have the 'tee piece trick' set up on mine as I described above?
the "tee piece trick" is to bypass the internal airways on the turbo carb ( or non existent airways on an n/a carb) and to link the float bowl to the plenum
linking the float bowl to the actuator aswell would still work however personally i would not, i like to give no reason for the fueling to be upset
any failure in the pipe from float bowl or actuator will result in a lean mixture
