Home > Help Needed / General Tech Chat > Changing tower bolts and dampers
johnnysti
Member #: 2480
Please could someone tell me what size socket i will need to remove the front subframe tower bolts? Also, might sound a stupid question, im replacing the front dampers and damper brackets but am not sure how to do it. Can i remove the old ones with the car on the ground or does it need to be raised off the ground? Just dont want to dammage the car! Thanks
feature=mhum
miniboy001
Member #: 8367
bucks
hi, the tower bolts are 33mm and i would say do it with the car raised!
ben
Ben H
Member #: 184
Melton Mowbray, Pie Country
You can change the dampers with the car on the ground or raised, but it is easier to do with the wheels off so on balance off the ground is better, imo.
http://www.twin-turbo.co.uk
johnnysti
Member #: 2480
brilliant! Thanks guys. Will get it sorted tomorrow!
feature=mhum
graemec
Member #: 1424
Carnforth, Lancs
The tower bolts are 1.5/16" AF - they are not metric.
If you choose to use the wrong tools then 33mm will prove a little tight, 34mm would be too loose but probably work. (1.5/16" = 33.3375mm).
As Ben says - you'll really need to remove the wheel to do anything with the dampers so you don't have much choice.
Depending on what dampers you have will depend whether they have any force in them - KYB will tend to push themselves open due to the gas pressure.
Mate i got the tool for it if you are okay to.waot untill thurs i can give yoi a hand as well
Last time I changed my front dampers I did it with the car on the ground and just turned the wheels out.
<5mins per side, bish-bash-bosh done.
graemec
Member #: 1424
Carnforth, Lancs
But he's doing the mounts too which makes it a bit trickier - may still be possible but for the sake of a jack and four wheel nuts I'd rather have the access.
spray the top mount bolts with penetrating oil asap - save having to deal with sheared bolts when you get round to the job
