Home > Help Needed / General Tech Chat > Engine restart after shutdown
Tom Jarrett
Member #: 9093
I recently purchased a 1968 MG Midget that has a race prepared 1275cc engine by C-Tech and a Garrett T3 turbo from a mini. My problem is restarting the engine after I have been driving. On occasion, the battery has run down trying to restart. I was told that the heat from the turbo may be affecting the carb and fuel left in it after shutdown. It is quite annoying to have to sit there and crank and crank before it finally catches. Any ideas?
Have you got a heatshield fitted to the carb?
Sounds like a result of fuel evaporation.
Bury your foot when starting it from hot, thats worked every time I've tried to start a turbo mini.
Tom Jarrett
Member #: 9093
Yes, I do have a heat shield one eye. I think evaporation is the problem but how do I fix the problem?
how about the bimetallic jet thingy,
lewisnoakes
Member #: 8451
warwick
Have a look into heat wrapping it or buying a turbo blanket to insulate it further. This is what I've done with mine and had no problems what so ever.
1/4 mile in....??
Only Time Will Tell!!!
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
bury your foot when starting from hot, job done
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
as said upside wot hot restart
