| Home > Technical Chat > Minispares Ally Beam | |||||||
![]() 1547 Posts Member #: 2727 Post Whore Bicester |
29th Sep, 2010 at 01:22:46pm
Just wondering if anyone has had any experience of this beam on the road?
1972 998 TURBO SLEEPER |
![]() 334 Posts Member #: 6647 Avon Park Class B winner 2010/11 milton keynes |
29th Sep, 2010 at 06:13:08pm
Ive had one for about 4 years and had no problems with it. I don't no if you no but the box section has great big blocks of ally to stop crushing of the box section and helps stop any deforming.
784 Posts Member #: 912 Post Whore North Yorkshire |
29th Sep, 2010 at 09:18:13pm
As Chris mentioned above. I had to mod mine in the same way to get it to fit. Its as if Minispares screwed up their measurements.
I drill holes in everything..! |
29th Sep, 2010 at 10:24:47pm
Make one.
Edited by minimole23 on 29th Sep, 2010. On 7th Oct, 2010 5haneJ said:
30th Sep, 2010 at 07:59:08am
What gets me is that you replace the subframe with a beam axle, but leave the cast arms on. They weigh more than the subframe! On 11th Feb, 2015 robert said:
30th Sep, 2010 at 08:46:09am
Thanks for the pictures and advice guys, im in the process of designing my own beam, aluminum is a consideration.
30th Sep, 2010 at 05:37:02pm
On 30th Sep, 2010 apbellamy said:
What gets me is that you replace the subframe with a beam axle, but leave the cast arms on. They weigh more than the subframe! When I have £450 quid lying around they will get replaced. I saved about 12kg over a standard subframe with brackets and everything else. Probably more when you consider the whole coilover assembly weighs only 1.8kg each side. Only about 4kg isn't there between standard and light radius arms? Edited by minimole23 on 30th Sep, 2010. On 7th Oct, 2010 5haneJ said:
