Home > Help Needed / General Tech Chat > it just wont go!
blister
Member #: 2590
Croydon
recently got my supercharged set up all fitted together so here is my problem it has trouble starting and and once it starts up it will just die but before it dies the revs build up on there own and then it dies!
to begin with the belt kept jumping off the supercharger pulley which i have now sorted but moving the pulley
engine spec is
1275 (9cc decom plate)
weber 40
eaton 45
suckthrough
i had it running before the charger was fitted running the weber 40 dcoe but now it just wont start
Mini_the_minx
Member #: 9077
Cheshire
Have you checked fuelling? Sounds to me like the engine is getting starved of fuel ie. The fuel gets to the engine hense the picking up then dies again.
On 2nd Nov, 2010 wil_h said:
blister
Member #: 2590
Croydon
well petrol is getting up into the carb because its in the pipe etc,
but it only starts if i put petrol down the bores of the carb
It sounds like an air leak.
Is everything on the carb tha should be plugged plugged, same for the SC. Are all the manifolds seated and sealed properly?
dischub
Member #: 8143
London
Sounds like an air leak to me too
blister
Member #: 2590
Croydon
well i believe that the carb manifold hasnt seated very well but i am not sure dont see why it shouldnt have as both surfaces are flat etc
i just went back to re seat the gasket and it hasnt moved and does create a seal
got a blow torch? whack it in the carb.
blister
Member #: 2590
Croydon
and what would this do?
an unlit torch will provide a fuel for the engine to run on,
if it starts then the fuels not getting in.
blister
Member #: 2590
Croydon
didnt no if you was serious then
will have to try that then i have been putting petrol down the barrels of the carb which seems like it starts the engine and it runs for about 3 seconds,
i dont have a fuel pump on the engine as yet but i know i will have to get one but this cannot be the problem can it? if the fuel is getting to the carb as the pump will only be needed once the revs are built up
Mini_the_minx
Member #: 9077
Cheshire
Erm, you need a fuel pump.
A standard fuel pump pumps fuel in at every rotation of the cam, your expecting the fuel to go up hill through a pipe with no pressure to push it? That might be your problem.
blister
Member #: 2590
Croydon
i asked vmax about needing one to just idle and he said it will start and run as long as it is not revved as it will just probly die
Carl S
Member #: 1761
Stalker
fit a high pressure fuel pump, problem solved.
blister
Member #: 2590
Croydon
but thinking about it that could also contrabute to the idle problem due to the sudden rush of petrol each time the cam turns
blister
Member #: 2590
Croydon
what sort of pump do you suggest solid facet
ahhhhh....
it will run on any fuel in the carb float chamber, but theres no way the engine will suck the fuel into the float chamber,
get a can of fuel and some hosem put the hose in the can and put it up high (roof of the car) and connect it to the carb fuel line, then suck on the flat vent pip of the carb...
this will siphone fuel into the flkoat chamber and should get it started.
errrm. There is some truth in the fact that you don't need a fuel pump. But how have you filled the float bowls up?
blister
Member #: 2590
Croydon
with the manual fuel pump that mounts onto the block
blister
Member #: 2590
Croydon
just trying to find out what fuel pump and regulator to get now but would this cure the problem?
Ben H
Member #: 184
Melton Mowbray, Pie Country
I doubt that the fuel pump will be the problem, but are you sure that the float chambers are full before cranking?
http://www.twin-turbo.co.uk
blister
Member #: 2590
Croydon
i would have expected them to be i will have to check as described above
blister
Member #: 2590
Croydon
ahhhhh....
is the flat vent pipe on the carb at the back where both the ram pipes are?
no theres usuallu one on the side.
the on that sticks up at an angle, 3/7
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=106
blister
Member #: 2590
Croydon
i got a weber though mate
