| Home > Help Needed / General Tech Chat > brack clearance on exacton wheels and a tyre question | |||||||
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
3rd Oct, 2010 at 06:17:55pm
first question is do they clear 7.9 vented discs?
cant beat a good blowout. |
1391 Posts Member #: 1686 Post Whore Oxford |
3rd Oct, 2010 at 08:27:32pm
First question, not a clue.
OMG Robert that's a big one |
![]() 136 Posts Member #: 5193 Advanced Member Dunstable |
4th Oct, 2010 at 11:15:18am
1st no they dont you would have to run a 17mm spacer or bigger |
4th Oct, 2010 at 05:13:55pm
17mm spacer?? really that big. dam it i just sold my 7.5s 4pots as i thought id go 7.9 vented.
784 Posts Member #: 912 Post Whore North Yorkshire |
4th Oct, 2010 at 11:53:48pm
1st Question = Yes.
I drill holes in everything..! |
5th Oct, 2010 at 10:50:07am
That looks amazing si.
Edited by cossierick on 5th Oct, 2010. |
5th Oct, 2010 at 04:14:26pm
basically ive got some exacton im getting converted to 6.5's ive decided on now. and want to know if they will clear my 7.9 vented minisport 4pot set up On 27th Apr, 2010 Rick.SPI said:
5th Oct, 2010 at 04:51:48pm
Ahh, sorry i didnt realise thats what the special wheels were called like on si's car, ive got a set to convert aswell, might have to check if they will fit on my 8.3's an 6pots, my normal force 10's do.
5th Oct, 2010 at 05:04:05pm
ok i dunno what munn racing is on about then. its just i dont want to get them converted if there not going to clear my brakes. On 27th Apr, 2010 Rick.SPI said:
5th Oct, 2010 at 07:01:47pm
Just pm si, hes running carls wheels as pic just check exactly what set up hes running
5th Oct, 2010 at 08:01:27pm
I think (Think) that its down to the caliper clearing the inner lip on the wheels, the ones I have seen have a stepped inner section. The TFM thread shows they wont clear the fiesta brakes, but they catch the caliper not the disc I run a supercharger and I don't care the TB is on the wrong side.
5th Oct, 2010 at 11:12:15pm
yer ive pm;d him already. well be good to find out :) On 27th Apr, 2010 Rick.SPI said:
6th Oct, 2010 at 07:59:14am
Most of the confusion is porbably down to the fact you didn't make it clear at the beginning you were planning on using Carl's splitties, rather than just standard Exactons.
6th Oct, 2010 at 10:03:40am
In theory it wont make a difference weather there standard or split'ed, as its only the front thats add'ed so back of the wheel stays the same.
6th Oct, 2010 at 10:24:43am
Yes, Rick, 100% correct. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
6th Oct, 2010 at 10:38:51am
yer i didnt need to say about them being conversion to splits as all it is doing is adding a dish on the outside edge which has nothing to do with brake clearance. aslong as there exacton wheels clear the brakes which si has confirmed as he is running the exact set up i am. then its fine. i could go 10x10 and it wouldnt make a differance to brake clearance just arch clearance and tyre probloms. as for the tyre question i did say 7x10 which i have decided agaist and am going for 6.5x10 On 27th Apr, 2010 Rick.SPI said:
6th Oct, 2010 at 10:46:57am
Aologies - I'd assumed Carl made them into a 3 piece split which, with a spun inner, would obviously affect clearance.
6th Oct, 2010 at 10:57:53am
haha fair enough. nope he just machines the the front of the wheel, taps them and fits the outer rim On 27th Apr, 2010 Rick.SPI said:
6th Oct, 2010 at 11:08:43am
if you have the setup why not mock build them? Drives
6th Oct, 2010 at 11:31:45am
because i dont have the wheels. the wheels are going to be going straight from richard to carl. no point sendint them to me then paying to send them to car l again. otherwise i would do this :( On 27th Apr, 2010 Rick.SPI said:
24th Jan, 2012 at 09:28:07am
sorry to bring this back up but im just going to order some brakes now and still havnt found a answer to this question.
24th Jan, 2012 at 10:33:29am
Get a single unmodified wheel and mock up. That is the only way to know 100% they will fit your actual bits. A single wheel can be had for £10-15 if you look around. Also useful to have as a spare anyway.
831 Posts Member #: 908 Post Whore gateshead |
24th Jan, 2012 at 11:34:07am
i run as set of 6x10 exacton force racing splits with a032r tyres. brakes are 7.9" vented discs with minisport 4 pots and mine clear. there is only a small gap, but they clear. balls to the blower!!!
24th Jan, 2012 at 12:51:44pm
I have wheels and no brakes ATM. I have 5 wheels. I'm going to get 7.9 minisport vented well if they clear which 2 people have now confirmed On 27th Apr, 2010 Rick.SPI said:
1083 Posts Member #: 8932 Post Whore |
24th Jan, 2012 at 12:52:42pm
Also the mini spares calipers are mean't to be better than the mini sport ones as they have 2 bleed screws instead of one. |
