Home > Wanted > 1275GT block + Set of rods.
Sam
Member #: 1686
Oxford
After a big bore A block, and a set of rods.
As close to oxford as possible.
Thanks
Samuealle
OMG Robert that's a big one
madcatminis
Member #: 5327
Dudley, West mids
I'm currently working a set of innocenti rods, Lightened and polished think they may be balanced (machining was carried out prior to me owning them) Looking at £100 for the set. Will post free. *happy*
I've got a set of standard pre A+ 1275 rod's. £20 plus post
I too have some 'A' rods, as well as loads of A+ rods.
It all depends what you are really looking for *wink*
Sam
Member #: 1686
Oxford
Poorly worded there. Most certainly a pre a+ block, but a+ rods would probably be preferable.
Scruffy
Member #: 328
Seaford Rise, South Australia
I have a 1275 A block on a std bore I believe. I will swap it for an A plus 1275 block. And you know where i live!!!
On 5th Sep, 2011 Vegard said:
Sam
Member #: 1686
Oxford
Unfortunately my last a+ (1380) block i sold, the only current one i have is unserviceable. being 73.5mm bore and slaughtering a ring. Now denoted for mocking up purposes.
Shame really.
A gt or an allegro block is what i really require. An s block is somewhat out of my budget.
Edited by Sam on 5th Oct, 2010.
turbominivanman
Member #: 1504
Westbury, Wiltshire
I think I have an 11 stud Austin 1300 GT engine in bits in the back of the garage.
And maybe a freshly .020 bored 1300GT 11 stud block, but minus bearing caps which I know you can buy green castings and have line bored to match the block.
Interested ?
Richard.
Interested
Sam
Member #: 1686
Oxford
van man, can you do me a favour and measure the deck height of the non bored block please?
Thanks
Samuealle.
Sam
Member #: 1686
Oxford
Still need a block, secured some rods!
turbominivanman
Member #: 1504
Westbury, Wiltshire
PM me Sam with what you are exactly after.
I'll get back to you better if you PM me as I'm a bit remote at the mo.
Richard.
minidave
Member #: 889
warlingham jct6 m25 nr gatwick
got a 1275 a series block with roads as from a gt all standand £150
cant fix it F:(k it
Sam
Member #: 1686
Oxford
Sorry Dave, that is most certainly above the price range i would be willing to pay.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Sam.
Defo have an Austin 1300GT 11 stud block, c/w main caps.
As I took the engine out of the car it came from and stripped it for storage, I have all the other engine parts if you're interested, including the cam, rods, pistons, head, twin 1.25 SU's etc.
Pics attached below, sorry they're a bit grainy, it was a bit dark at the back of the garage.
If you want the lot, just ask.
Have sent you a reply to the PM you sent me.
Richard.
richard, are you interested in a morris 1300GT?
turbominivanman
Member #: 1504
Westbury, Wiltshire
Thanks for the offer Rubes but I'm downsizing. The GT I broke in the '80's was a G Reg 1969 job, amazing car. However, I'm not looking for another !
Hopefully Sam will take the engine I have as it's a good one - I think they were based on thick flange S blocks but without tappet chest covers, not sure. The engine number on the block I have for Sam is 12H/298F/32998. Maybe someone else can advise.
Richard.
