Home > Technical Chat > cruise conditions
turboestate
Member #: 362
durham area
hi there does anyone have any problems with missfireing at cruse speed just befor turbo pics up, please help*surprised*
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
AllanMcD
Member #: 414
Dalbeattie Scotland
That is likley just to be a standard non turbo isue ie coil , plugs , leads , dizy cap, or maybe the needle
http://www.rabdunn.co.uk/
turboestate
Member #: 362
durham area
COIL DIZZY CAP LEADS AND PLUGS HAVE ALL BEING CHANGED THE NEEDLE WAS OK ON ROLLERS AND AIR/FUEL RATIO IS SPOT ON RIGHT THROUGH REV RANGE EVEN WHEN MISSFIRE OCCURS
______
/___|_____
_ (@)___(@)
Kean
Member #: 341
aka T2clubby
South Staffs
Make sure the timing is bang on and the plug gaps are correct :)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
coil or plugs I would guess..
what are you running?
Alex
AlexF
giallofly
Member #: 164
The Stig..
Newport Pagnell
Might sound a silly question but what head have you got?
Modded,valves,guides?
may just been a bit highly strung as jon's suggesting. i had a 1293 NA that was a bitch until 4k!!
giallofly
Member #: 164
The Stig..
Newport Pagnell
The reason i asked is that i had a missfire at cruising speed and it turned out to be 2 exhaust guides nipping up, they were bronze on crome valves. I too thought it was ignition.
Edited by giallofly on 22nd Feb, 2005.
turboestate
Member #: 362
durham area
Hi there its a standard head with worked chambers the valves an guides are all standard with 280LB springs, cant realy test the car with all the snow weve got will be cheking out the timing though, whats every one else runing the timing at with (10 PSI BOOST)*oh well*
Edited by turboestate on 24th Feb, 2005.
______
/___|_____
_ (@)___(@)
280lb springs?? Jeez.. Stiffer than my nipples when bathing naked in the snow....
Edited by Vegard on 25th Feb, 2005.
b16_b
Member #: 429
newcastle upon tyne
lmfao! cant beat a ice bath!
