| Home > Good Garages & Parts Suppliers > force racing....carl austin | |||||||
4th Oct, 2010 at 09:46:17pm
hi
My build thread..
4th Oct, 2010 at 10:04:26pm
Photos please! Do they need inner tubes? |
5th Oct, 2010 at 08:48:38pm
hi
My build thread..
5th Oct, 2010 at 10:30:12pm
ooo exciting I pick mine up on Thursday. I run a supercharger and I don't care the TB is on the wrong side.
5th Oct, 2010 at 11:30:56pm
Regards inner tubes, they do make things easier with the wide 10's when it comes to getting tyres on, as the well is a long way from the front rim due to the dish. However if you can find a decent and careful tyre fitter you can build them with bolt in valves and seal the rims together, before having the tyres fitted.
5th Oct, 2010 at 11:39:11pm
I built my own Tom fitted the tyrs and sealed them, no issues in the last 3 years Crystal Sound Audio said:
27th Dec, 2010 at 07:12:32pm
What did you use to seal the rims Neil/Tom?
27th Dec, 2010 at 07:29:24pm
After having a closer look at mine i think its possible to get tyre on the rims then seal the two together then bolt up dont know how good the seal would be though and a cu"t to split again. Im going for fully sealed then tyres on with alot of lube maybe try rims in the freezer and heat the tyres abit see if its easyer to get them on then lol. Drives
27th Dec, 2010 at 10:48:40pm
5th Jan, 2011 at 06:59:01pm
im going to get the tyers fitted soon by my mate.
My build thread..
5th Jan, 2011 at 09:21:14pm
On 5th Jan, 2011 JT said:
im going to get the tyers fitted soon by my mate. when it comes to balancing them up, do you use stick on weights? if so, do they clear the calipers? iv got KAD 4 pots with vented discs (7.9") going on but i cant fit them as i havnt got my discs and drive flanges yet. so if stick on weights are not ok, then will i have to use those clip on types? you realy need to be using stick on, and any that need to go on the outside se if he he can try putting them behind the centre on the inner rim, the wheels will be quite good for balance due to method of constuction, also note, be carefull not to snag the tyre on the valve inside the wheel, as it will not allow the tyre to drop down into the well fully to allow the other side to drop over the rim, carl thanks josh |
5th Jan, 2011 at 09:32:44pm
thanks carl is there any pics of your wheels all balaned up? showing where the weights are put?
My build thread..
![]() 484 Posts Member #: 4755 Senior Member warwickshire |
5th Jan, 2011 at 09:39:37pm
I've never had to have mine balanced
2012 Avon class c 2nd place 13.8 @98mph |
5th Jan, 2011 at 09:45:24pm
On 5th Jan, 2011 1380rich said:
I've never had to have mine balanced Rich i was just about to say that too, carl |
5th Jan, 2011 at 10:27:46pm
ok i will just not both to balance them then!! easy lol
My build thread..
5th Jan, 2011 at 10:33:15pm
None at all even with the 10 x 7's
5th Jan, 2011 at 10:36:46pm
o well proplem solved!! lol
My build thread..
5th Jan, 2011 at 11:04:31pm
not at 127mph for me, in 10.82 second btw,lol |
5th Jan, 2011 at 11:25:17pm
well thats good enough for me then! lol My build thread..
