| Home > General Chat > O/T coil springs, stupid question | |||||||
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
4th Oct, 2010 at 11:10:32pm
I fitted a set of lowering springs to my 200sx yesterday and am concerned how close some of the coils are when the car sits on the deck.
4th Oct, 2010 at 11:14:22pm
progressive springs are like this, the closer the coils the softer the spring this allows for travel without the spring dislocating however they do look a bit close together
4th Oct, 2010 at 11:32:41pm
Cheers Neil, they are Apex coils, looking close is one thing, but these touch, the picture is with the car jacked up to take the pictue.
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
5th Oct, 2010 at 06:10:36pm
Its right Shane, mind did the same - its to allow the car to run low enough, but also so that the spring expands and doesn't come loose from the seat when at full extension. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
5th Oct, 2010 at 06:15:49pm
Thats just what i wanted to hear as IM now headed out in the workshop to put the correct way up.
6th Oct, 2010 at 09:57:06am
Progressive springs on lowered cars work in that the two windings compress at different rates allowing for the shock to absorb small bumps but also be able to absorb larger bumps with the same ride comfort otherwise every bump in the road would feel like landing on your arse after jumping of a cliff. Own the day
