Home > Help Needed / General Tech Chat > Changing front wheel studs
johnnysti
Member #: 2480
On the way back from combe the other saturday, my o/s/f wheel decided to try and detatch itself from the car and resulted in an AA tow home! This would answer the mental torque steer i was suffering from! It would appear that when the ally 4pots were fitted and the disc conversion to fit under 10" alloys, no one changed the studs as there are 1" spacers on there. So, the nuts pulled through killing the threads. All the other wheels are fine. My question is do i need to take the discs/hubs off the car to replace the studs? I tapped one of the dead studs out to check its length but am not sure how to get it to locate fully without taking the whole thing out and sticking it in a vice. Can anyone help please.
feature=mhum
you have to undo the castle nut and remove the drive flange, you will need a vice to change them without damaging anything
Edited by wolfie on 5th Oct, 2010.
just_jack
Member #: 2928
peterborough
could you not put it through, line it up, find a thick enough spacer and pull it through with the wheel nut? or is that bodging?
Jack Jones
i dont think you can get the longer studs in without taking the flange off as wolfie says
drifting the longer ones into place should be easy from there
jacks method is a possibility, but as a last resort imo
I just pull them in with an old wheel nut, and if needed some washers, and then just check the nuts after a few trips round the block
just_jack
Member #: 2928
peterborough
Saying that, Think Brett may be right with an inch spacer it might be a tight squeeze getting it to go through
Jack Jones
1" spacers on the front ?! and you wonder why it torque steers?
it shouldnt have anything to do with the spacers, i just remember i had to take mine of to fit them, i snapped a stud undoing them once, and changed the lot for piece of mind, i dont think i put especially long studs in there either,
Mr Joshua
Member #: 1954
Luton Bedfordshire
You will have to take the drive flange off as there is not enougth of an angle to get the loger studs in or for that matter the whole original studs out. Been down this road before.
To get them in you can line the knurling up by feel then drift them in with a bar and kin heavy hammer or a press if you have one.
Own the day
Mr Joshua
Member #: 1954
Luton Bedfordshire
Also if your running with an inch spacer are you not better of fitting wheel adaptors? If your offset is still around 50/50 I dont see an issue with 1" spacers but if there is no support between the drive flange and the knave face of the wheel you are putting torsional loads into the equation and I dont think your studs will like that.
Own the day
