Home > Technical Chat > Tb025 turbo housing
almichie
Member #: 2065
Does the Garrett TB025 have the same exhaust housing as the aireasrarch T2?? I'm
Thinking it does, can anyone correct me?
Shaft seems nice and snug
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
it's compatible but isn't the same,, it's bigger,
you have take the complete exhaust side of each turbo:
turbine/backplate/hsg
almichie
Member #: 2065
Ok, well that's not all bad then. I suppose the turbine from that turbo will change the chAractoristics of the originally.
The tb025 in question is off the Renault 19 TD, any thoughts??
fab
Member #: 100
Paris' suburb
they're no tb025 used on a 19 td.
it's tb0255, which is in fact a t2:
std turbine, 0.41 A/r hot side and t2 55 compressor trim
Good turbo even if largely dated cause of his typo of turbine.but his low inertia and higher flow turbine hsg than the 0.35 used on renault 5,and the fact that it should also have a semi divorced wastgate which is good to, still give him a good choice
