Home > Help Needed / General Tech Chat > Floor mounted pedal box
Alex Gibson
Member #: 7760
Hi all, I am looking to fit a floor mounted pedal box to my race car project.
What size master cylinders should i get for the front, rear and clutch?
I will be running mini spares 4 pots, drums on the rear and a non verto clutch.
The kit is advertised with 3x master cylinders (.625,.7 and a .75)
Anyone fitted one or know the sizes please?
Cheers, Alex*tongue*
Scruffy
Member #: 328
Seaford Rise, South Australia
0.625F & .75R although you might need to go bigger on the rear or fit a limiter as I have had to to
On 5th Sep, 2011 Vegard said:
Alex Gibson
Member #: 7760
Why a bigger cylinder for the rear?
I would have thought more volume and pressure for the front calipers = bigger a cylinder for the front.
Or am i missing the point?
With thanks, Alex
miniminor63
Member #: 672
The oversills police
Oslo, Norway
you are missing the point :) smaller cylinders give more pressure
Alex Gibson
Member #: 7760
:$ Makes sense really :$ Thanks guys! 8-)
Cheers, Alex
iirc you can get 7/8 rear cylinders from rally design
G13B
Member #: 1376
check the ratio on the box too,
5:1 / 6:1 etc
You all are missing the point. There's no room for the master cylinders unless they are inverted *wink*
5portsrock
Member #: 2023
nr Portsmouth ,Hampshire
Line Pressure Comparison
The table below shows the range of bore sizes available and shows the % step up from the previous size and line pressure based on 50 lb pedal load and a 5 to 1 pedal ratio.
Master Cylinder Size mm/in. 14.00/
0.551" 15.00/
0.591" 15.875/
0.625" 16.80/
0.661" 17.78/
0.70" 19.05/
0.75" 20.638/
0.8125" 22.225/
0.875" 23.813/
0.9375" 25.4/
1.00"
Area sq in. 0.2386 0.2739 0.3068 0.3436 0.3848 0.4418 0.5185 0.6013 0.6903 0.7854
% step up from previous size N/A 14.8% 12.0% 12.0% 12.0% 14.8% 17.4% 16.0% 14.8% 13.8%
Pedal Load lb. 50 50 50 50 50 50 50 50 50 50
Pedal Ratio 5:1 5:1 5:1 5:1 5:1 5:1 5:1 5:1 5:1 5:1
Line Pressure p.s.i. (single cylinder) 1047.76 912.72 814.87 727.61 649.61 565.88 482.17 415.75 362.17 318.31
Johnny
Member #: 6926
Accrington
i bought a pedal box a while ago (wilwood) and it came with the master cylinders (2x tilton 1x wilwood)
after reading this i think i definately have the wrong ones :(
it came with a
0.75 for the clutch?
7/8" for the front?
1" for the rear?
and it says in the instructions its either 5:1 ratio OR 6.25:1 but im not sure on how to change it as there is only 1 hole in the pedals and only 1 slot in the box.
will this mean that the pedals will have to move further to give the same result as the smaller ones? AND will i also need to apply more pressure, if so. how much more pressure? is it a problem or not?
Thank you
Edited by Johnny on 8th Jan, 2012.
Does it not have a balance bar? This is the usual way to adjust the front to rear balance; effectively altering the the pedal ratio between the two cyliners.
Johnny
Member #: 6926
Accrington
yes, it has a balance bar. but the drawing in the manual looks like it meant the pedal. i thought the balance bar was the bias?
