Home > Help Needed / General Tech Chat > Mk1 conversion
turbomikee
Member #: 8744
Has anyone got any pictures or describe how they fitted there mk1 rear light conversion plates? Thanks mike
I dont have any of mine but i onky have one side done atm it was abit of a bitch as the plates i got wernt very good. Its really alot.of trial and error imo just little tacks in place untill its where you want it and then weld it in bt make sure its strait *smiley*
turbomikee
Member #: 8744
Did you cut the inside where the mk3 lights sit out befor you tacked the plate on?
dazibee
Member #: 1356
TRURO, CORNWALL
You can cut the inside bracket out or leave it in if you choose
Oli
Member #: 1910
Wilts
the plates are shit. and look shit close up im affraid. just not pressed deep enough.
dazibee
Member #: 1356
TRURO, CORNWALL
Yea I had to reprofile mine with fibre glass as they did not have the little platform which the light sits on top of.
However the plates on this car
:http://www.turbominis.co.uk/forums/index.php?p=vt&tid=329261&fr=75
look a lot better so perhaps the design has been improved.
