| Home > Help Needed / General Tech Chat > Fitting front hilos | |||||||
236 Posts Member #: 243 Senior Member Portsmouth |
22nd Feb, 2005 at 05:39:40pm
Hi all jus came in from the garage chucked me tools on the floor in disgust, Do you need to use a cone compressor tool to fit the hilos to the front subframe? I read somewhere that you dont need to but my hilos won't adjust any more to get the hilo in without compressing the rubber cone it needs about 1/4 of an inch more to go in. and when trying to compress the cone there was a loud bang and a stripped tool WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
22nd Feb, 2005 at 05:49:00pm
Yes buddy you usually do need to compress the cones to get the hilos in. Sometimes like you say, you can get away with it, but commonly you need to compress the cone. If it has stripped all is not lost, if there is no trumpet in there either take it out and re-tap the hole, or get a nut on the trumpet side of the cone and screw your compressor into that.
22nd Feb, 2005 at 05:54:14pm
Ahh cheers Tom, slight prob tho i stripped the tool not the thread in the cone and i spent all lunch making a new rod because the last thread stripped! This is why im annoyed. Guess the only way is to buy a new compression tool.
22nd Feb, 2005 at 05:57:47pm
Make sure you are using the correct threaded part of the tool. Earlier cars have an imperial thread, later ones a metric thread. The imperial thread is much finer than the metric. From memory I think the imperial is 1/2 UNF and the metric M14 but I could well be wrong on that. I think the changeover date was 1976 when the front subframe became rubber mounted, again one for correction possibly, I can't remember any more.
22nd Feb, 2005 at 06:14:03pm
Ahh thats prob the problem then its 1986 car but wasnt sure if they were still imperial or not. Rite cheers tom il make a new shaft with a 14mm thread on it. only got the imperial shaft because its a really old tool
22nd Feb, 2005 at 06:25:12pm
Check that it is M14 before you go making something!! I _think_ it is, but I am not 100% certain.
244 Posts Member #: 34 Senior Member |
22nd Feb, 2005 at 08:45:14pm
I managed to squeeze my hi low in without a cone compresser, using new cones.
23rd Feb, 2005 at 03:16:06pm
sorry to hear about it Matt but thats life s***e happens sometimes Edited by BENROSS on 23rd Feb, 2005.
23rd Feb, 2005 at 03:30:16pm
Tip....
23rd Feb, 2005 at 05:38:46pm
Ahh rite yer its 14 mm il try drilling and tapping to 16mm then. The subframe is outta the car and im putting hilos in but they are 1/4 of an inch to big to fit under the cone without compressing it. its getting annoying now lol
23rd Feb, 2005 at 07:40:33pm
Have you removed the small rubber rebound stop (one fitted with single phillips screw) this gives a little more clearance to fit hilos without compressing cone. Failing that should be an easy job (as subframe is out) to whip off the top arm, assemble knuckle joint and hilo then refit. Edited by T3Tone on 23rd Feb, 2005. -MINI CLUBMAN 1380 TURBO- |
23rd Feb, 2005 at 08:26:50pm
iv fitted and removed std trumpets before without a cone compressor by simply removeing the bottom arms. didnt take to long. turbo 16v k-series 11.9@118.9 :)
24th Feb, 2005 at 12:11:10pm
The problem is that on many of cars, the cones have been changed at sometime. It's essential that you find the proper thread... Don't take the pre/post76 as gospel
![]() 63 Posts Member #: 264 Advanced Member Southampton |
28th Feb, 2005 at 09:19:55pm
Is the compression tool possible to make as I begrudge paying the RRP for them? Yes, Im getting there.....
28th Feb, 2005 at 09:47:07pm
You proberly could make one but its not really that easy to make lots of different types of threads in it. I made a new shaft for mine (the bit that screws into the cone) But got the actual tool second hand from the free-ads worth checking those i guess. By the way thanks for yor help guys got the hilos in and the subframe is on the car jus gotta connect the brake lines etc and get everything ready for the engine hopefully will be in next month! WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
