| Home > 998cc > 12g295 just cracked on me AAAARRRGGGHHH | |||||||
109 Posts Member #: 8630 Advanced Member |
12th Oct, 2010 at 11:52:29am
wanted to get my car on the road for this weekend and when i was putting the new thermostat studs in one of them has cracked straight threw the block.
12th Oct, 2010 at 12:01:28pm
If your worried about excessive CR and it's just to move it you could disconnect the wastgate actuator and wire the lever arm so the wastgate is wide open all the time and use the standard head. Providing the turbo is all conncted for oil etc, it will just spin fairly slowly and develop no boost with the wastegate heldwide open. Schrödinger's cat - so which one am I ??? |
12th Oct, 2010 at 12:07:20pm
On 12th Oct, 2010 smudger483 said:
wanted to get my car on the road for this weekend and when i was putting the new thermostat studs in one of them has cracked straight threw the block. Please elaborate. This was very eloquently put. On 13th Jul, 2012 Ben H said:
12th Oct, 2010 at 12:10:06pm
the stud closet to the radiator has cracked the block on both the front and back of the head |
12th Oct, 2010 at 12:11:23pm
Sorry, what is cracked? The head or the block? I still don't get it. On 13th Jul, 2012 Ben H said:
12th Oct, 2010 at 12:11:59pm
the head |
12th Oct, 2010 at 12:14:38pm
On 12th Oct, 2010 Rod S said:
If your worried about excessive CR and it's just to move it you could disconnect the wastgate actuator and wire the lever arm so the wastgate is wide open all the time and use the standard head. Providing the turbo is all conncted for oil etc, it will just spin fairly slowly and develop no boost with the wastegate heldwide open. so what would happen if i ran the car on 5 psi of boost |
12th Oct, 2010 at 12:22:59pm
if the compression isn't sky high and your fuelling and timing are good then it will be ok. If something is worth doing, it's worth doing half of. |
12th Oct, 2010 at 12:40:37pm
thanks for the advice hopefully trying to source another 12g295 head for the long run |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
12th Oct, 2010 at 03:30:52pm
if it's only cracked through the very end around the stat housing, can it not be welded up? Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
12th Oct, 2010 at 03:33:51pm
Braize it I seriously doubt it! |
12th Oct, 2010 at 03:35:47pm
On 12th Oct, 2010 paul wiginton said:
Braize it mmm cylinder head stew. In the oven on a low heat with some onions and gravy. Should be nice after about 3 hours. On 11th Feb, 2015 robert said:
12th Oct, 2010 at 03:37:01pm
And suet dumplings I seriously doubt it! |
12th Oct, 2010 at 03:37:38pm
i was thinking that could anybody braze it for me that lives in the yorkshire area |
12th Oct, 2010 at 03:40:09pm
PM Benross, he's very good with cylinder heads.
12th Oct, 2010 at 03:44:52pm
On 12th Oct, 2010 apbellamy said:
Paul - Carrots and broccoli on the side? Jam roly poly and custard for pudding? I think so. You could look for local bodyshops or metal fabricators who have oxy/acetylene equipment I seriously doubt it! |
12th Oct, 2010 at 03:45:27pm
ok thanks will do and when i get the head off tonight or tomorrow ill post a pic to show you all Edited by smudger483 on 12th Oct, 2010. |
12th Oct, 2010 at 05:32:13pm
wanted to get my car on the road for this weekend and when i was putting the new thermostat studs in one of them has cracked straight threw the block. Please elaborate. This was very eloquently put. er do you meant 'was not' very eloquently put v ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
12th Oct, 2010 at 05:50:13pm
