| Home > General Chat > New car - what to get? | |||||||
329 Posts Member #: 3193 Senior Member Torbay, Devon |
12th Oct, 2010 at 05:32:23pm
12th Oct, 2010 at 06:20:22pm
The only the two things I don't like about my A4 saloon are the lack of split/folding rear seats and the atrocious rear leg room - I'm 6'5" and my 4 year old niece doesn't fit behind me. That's 2 clicks from the rear setting. On 11th Feb, 2015 robert said:
12th Oct, 2010 at 06:38:07pm
As above, the A6 sorts this out though and is a nice thing to smoke about in, a bloke I know has a A6 with the smaller 2.4 V6 in, still goes pretty well, and can be got dirt cheap. Also the A6 didn't change much, if at all, from 1997 till about 2003, so if the age thing bothers you, an earlier one with a private plate can be any age.
12th Oct, 2010 at 06:56:08pm
Thanks for the replies, I have spoke to several people and the Audi seems to come out on top each time.
12th Oct, 2010 at 06:59:14pm
Can be expensive when you unexpected and stupidly brake something... On 11th Feb, 2015 robert said:
12th Oct, 2010 at 07:00:16pm
A6 should be a good option as its more likely to have the leather
288 Posts Member #: 6267 Senior Member Bristol |
12th Oct, 2010 at 08:22:17pm
I would chose either of those Audis, but I'm a bit biased. I've had 2 Audis with the 12v version of the 2.8, I love the engine but it is not economical. I get 20MPG driving to work and never more than 30MPG from a tank. |
1050 Posts Member #: 764 Post Whore Staffordshire |
15th Oct, 2010 at 01:52:38pm
i was looking for a similar car a while ago but accidently found a saab 9-5 which im very pleased with. |
15th Oct, 2010 at 01:54:35pm
Have you found your boost yet though Anton? If something is worth doing, it's worth doing half of. |
15th Oct, 2010 at 02:00:23pm
well other than an issue im having atm im pleased with it...
15th Oct, 2010 at 02:01:30pm
"i'm in the JAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAYG"!!!
15th Oct, 2010 at 02:23:08pm
I say jag... its a mundarno in disguise... |
15th Oct, 2010 at 02:29:44pm
Still better than last time I had to use my dads car! It was a maroon 3.2 V6 Vectra with a tan leather interior! If something is worth doing, it's worth doing half of. |
5th Dec, 2010 at 05:54:37pm
Just an update:
5th Dec, 2010 at 06:39:25pm
i have a V70 T5, cannot fault it, well bar the fuel usage but tuff for now, if i was to buy another ( and i probably will at some point) it may well be a Diesel awd would be nice too,
Yes i moved to the darkside |
5th Dec, 2010 at 07:05:05pm
On 12th Oct, 2010 jonb_5 said:
Hi, I travel only a couple of miles a day to work Thanks Jon Get something even less practical and faster, and buy a bike. I honestly can't understand why people who live under 5 miles from work drive. Unless they needed the vehicle to travel to clients ect. On 7th Oct, 2010 5haneJ said:
5th Dec, 2010 at 07:16:54pm
Another vote for the V70 here, I would definitely buy another one. The most useful and comfortable car I have owned, and quick to boot. |
5th Dec, 2010 at 07:41:11pm
Hi
5th Dec, 2010 at 07:57:19pm
I've got the S60 (V70 but saloon) D5 (163bhp) and Its superb - returns 55mpg. The SE commands more money but gets full leather (rather than half on the S spec), dolby surround (S gets 2 channel but still great audio), digital climate control (dual zone on the S manual control). So the S spec is good value for money. The early D5 had some issues with injectors (upto 2004) and many were replaced on warranty. starting trouble is first signs of failure. I have looked into it and there arn't that bad to replace (unless you goto Volvo!)
5th Dec, 2010 at 08:31:17pm
common faults, the alarm backup battery leaks and eats through the pcb, expensive fix diy kits are available about 300dolla
