Home > General Chat > These pistons any good? Bore sizes
http://www.minispares.com/web/Item/P22357%2D40/InvDetail.cfm
Just wondering whether to go +40 since the block ive got is in good nick but has already had a +20 rebore. I want things to be nice and fresh.
Or should i go with the omega pistons (not forged) but i believe these are only available in +20?
Is a +40 going to be reliable? If not then ill find a previously unbored block and go +20
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
your going to end up with a high CR thou... remember that for each rebore, you end up with a higher CR... those extra cc's of displacement have to go somewhere!
Other than that, 40 thou should be ok on a std ish turbo... which I assume ur going for with the std CR.
alex
AlexF
minimark
Member #: 19
newcastle
mmmmmmmmmm
explain that one to me please again
if you overbore your block your c/r goes up
mmmmmmmmmm
if your block face to piston height stays the same.
explain how the extra volume ( ok i know its a small amount ) makes your c/r go up???????????????????????
As for +40 bore
At 20 psi , 8/1 c/r and 5 years of abuse mine seems to run ok
The bigger diameter the pistons,the greater the swept volume, meaning greater combustion chamber volume required for given compression ratio.
So say you had an engine and took it out to 1310 or whatever, and left everything else the same inc volume above the piston you would have a higher c/r so would have to run slightly lower boost.
Phil. *smiley*
minimark
Member #: 19
newcastle
sorry i stand totally corected
much humble pie
thick geordie
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
lol its ok its not obvious...
same area to sqeeze more cc's into :)
alex
AlexF
stupid arsehole! northern monkey!
lol
sorted those toys yet Mark?
Aaah, resurrection at its very best.
What is the general consencus on the 22357 pistons??
http://www.minispares.com/Product.aspx?ty=...BO%20MEGA%209...
I'm building a new turbo engine in a while, and these might be appropriate for me. Any info? Iain??
5 1/2 years!!! lol
