Home > Beginners Tech > Engine spec
minimad_211
Member #: 9127
Hi guys,ive had my mini for 11years and have bought a metro turbo engine to put in it at some point over the next year.im unsure what would be the best spec to go for to get a reliable increase in power.id like around 120bhp and have the car set for fast road and track use.i dont intend to do it as cheap as possible but at the same time i dont want to be spending fortunes!!! Any suggestions?
Everything you need to know can be found using the Search function.
Paul
Edited by paul wiginton on 15th Oct, 2010.
for 120bhp rebuild it to standard spec + a x-pin diff, fit an intercooler and raise the boost a bit.
have a read on www.turbo-mini.com there's loads of info there. Also have a read of the beginners tech section here.
