Home > Help Needed / General Tech Chat > stainless exhaust tubing
I know the grade needs to be 321 but what internal size do i need? i really want to have a pop at this myself, is there a standard wall thickness?
best place to buy?
Edited by wolfie on 15th Oct, 2010.
Good luck!
310 might be easier to find. I gave in and used 304. 316 has been used too.
Edited by Sprocket on 15th Oct, 2010.
321 is the ideal grade for stainless exhaust manifolds, but you will find it very difficult to source pipes and/or fittings in small quantities.
I've used Sched. 10 316 pipe and fittings, which are readily available. Done over 1000 hard miles so far without a problem.
http://www.allstainlessltd.co.uk/
advantage998
Member #: 1840
Kings Lynn, Norfolk
I've also brought 304, havent welded it up yet mind. Got my stuff from http://www.pipecenter.co.uk.
quinton
Member #: 1911
Whats this for niel? your down-pipe? or the entire system?
316 is fine for downpipes etc, as said 321 is hard to find.
to make a manifold quinton
My manifold is 304 stainless, looks fine after 6k miles.
I had a good book mark for pipe and elbows but lost it, essentially mini is schedule 10 pipe, 1 1/4" iirc,
this sort of place should do it cheap.
http://www.jsfstainless.com/pages/products...Bore%20Fittings
miniminor63
Member #: 672
The oversills police
Oslo, Norway
for 321 pipe an collector : http://www.burnsstainless.com/
http://guide.bssindustrial.co.uk/pdf/silver_section_10.pdf
EricsAmerica
Member #: 7891
Annapolis, MD USA
I use them here in the US...good company to deal with.
Eric
my pics.... http://www.fototime.com/inv/7AAF37CF3EFA956
