Home > Help Needed / General Tech Chat > narrowband wiring
eden7842
Member #: 8852
leicestershire
hey
has anyone got a wiring diagram for a narrowband gauge with a 4 wire sensor ?
cheers
Does this help ? http://www.turbo-mini.com/59247/59392.html
eden7842
Member #: 8852
leicestershire
no ive looked at that, i need to know how it wires to my gauge. i think i may either be missing something or ive confused myself
its simple you will have 2 for a heater within the narrow band sensor, one for an earth and one will be signal,
Phils link contains all the correct info buddy
Lambda Wiring.
* 1 Wire Sensor - Black - Signal to gauge
* 2 Wire Sensor - Black - Signal to gauge
* - White - Earth
* 3 Wire Sensor - Black - Signal to gauge
* - White - Heater x2
* 4 Wire Sensor - Black - Signal to gauge
* - Grey - Earth
Bear in mind this may not be correct for all Lambdas !
eden7842
Member #: 8852
leicestershire
ok so am i right in saying all i need its a gauge + lamba?
and wat do i do with the heater wires? 12v+ and negative earth
thanks all
