Home > Technical Chat > Valve in plenum
millermilla
Member #: 9126
Burgess Hill, West Sussex
Hiya, I have a 1990 ERA turbo that is just undergoing a top end rebuild. Before the strip down if I ran anything over 0.5 bar I could hear air escaping under the bonnet and I spent a lot of time trying to find where it was coming from. Now I've stripped it down I see there is a valve (Dump valve?) built into the inlet pipe bolted to the back of the carb. What do you do with this if you want to run more boost?
Thanks
www.shine-ebits.co.uk
Weld it up or pack it out with coins.
this is an over boost device originally fittet to the metro turbo
run a 3/8"bsp tap down there and fit a blank,
the hole size is a little large only a fraction but it gives more than enough thread in there
