| Home > Technical Chat > Turbocharger Air Flow | |||||||
24th Oct, 2010 at 10:04:35am
I've often wondered why some turbocharger maps hit a flow limit on the choke line on the right hand edge.
Edited by Paul S on 24th Oct, 2010. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
24th Oct, 2010 at 10:12:21pm
And the point of this thread ???
25th Oct, 2010 at 04:01:58am
go on then whats the theoretical max for the gt17 and gt20? :)
Edited by Brett on 25th Oct, 2010. Yes i moved to the darkside |
25th Oct, 2010 at 01:48:42pm
Good stuff Paul. Do those with the choke line have a certain wheel inducer vs wheel diameter ratio? - i.e. any wheel of a certain inducer/ diameter ratio is guaranteed to have this issue? On 17th Nov, 2014 Tom Fenton said:
25th Oct, 2010 at 02:07:29pm
I think that they all do, it's just that Garrett do not plot the whole map for most turbos.
857 Posts Member #: 1778 Post Whore Northants |
25th Oct, 2010 at 04:47:47pm
Not the gt3076 or the 71? |
25th Oct, 2010 at 04:54:10pm
On 25th Oct, 2010 sturgeo said:
Not the gt3076 or the 71? No, but they do conform to the general trend. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
![]() 338 Posts Member #: 1911 Senior Member Swindon |
3rd Nov, 2010 at 10:28:53pm
Just looking through some flow charts I can across this and then noticed you didn't filter into your results.
4th Nov, 2010 at 08:54:24am
On 3rd Nov, 2010 quinton said:
Just looking through some flow charts I can across this and then noticed you didn't filter into your results. Surely this is another good choice for us? Thought I'd leave it to you experts as I'm still trying to understand these compressor maps. http://www.turbobygarrett.com/turbobygarre...4R_471171_9.htm That is the same compressor performance as the GT2554 but has a larger turbine, so will take longer to spool up. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4th Nov, 2010 at 09:03:59am
there is ony 0.8 mm turb diam difference from these two, don't think it will be any noticable , especially that the disco potatoes have a 10% more efficient turbine.
Just looking through some flow charts I can across this and then noticed you didn't filter into your results. Surely this is another good choice for us? Thought I'd leave it to you experts as I'm still trying to understand these compressor maps. http://www.turbobygarrett.com/turbobygarre...4R_471171_9.htm That is the same compressor performance as the GT2554 but has a larger turbine, so will take longer to spool up. |
4th Nov, 2010 at 12:20:04pm
Don't guess, do the calcs on the turbine map:
4th Nov, 2010 at 07:07:45pm
I do like calcs,
4th Nov, 2010 at 07:11:57pm
Schrödinger's cat... On 28th Aug, 2011 Kean said:
4th Nov, 2010 at 08:20:17pm
calculer deux fois, une fois la construction
4th Nov, 2010 at 09:07:13pm
