| Home > Help Needed / General Tech Chat > Bore sizes exhaust and induction | |||||||
![]() 296 Posts Member #: 9117 Senior Member Northampton |
25th Oct, 2010 at 09:30:00am
Hi hoping you guys could answer a couple of questions,
Confessed addiction to everything mini |
25th Oct, 2010 at 09:35:28am
Firstly. TD once calulated the optimum sise bore for IC tubing. But it was not a commonly available hose size, so most people use 50mm.
25th Oct, 2010 at 09:45:28am
You could move the selector inside? If something is worth doing, it's worth doing half of. |
25th Oct, 2010 at 12:13:11pm
Thanks Wil_h perfect Confessed addiction to everything mini |
25th Oct, 2010 at 02:24:25pm
You could also use two exhaust short rubbers unstead of the long selectors ones.
On 25th Oct, 2010 John said:
You could move the selector inside? |
25th Oct, 2010 at 02:25:56pm
All these flow are related to your engine flow,
25th Oct, 2010 at 03:54:05pm
On 25th Oct, 2010 wil_h said:
Firstly. TD once calulated the optimum sise bore for IC tubing. But it was not a commonly available hose size, so most people use 50mm.. That was probably when most 'hot' turbo minis had 150hp, and only woodsie had a genuine 200... Oh how things change! On 17th Nov, 2014 Tom Fenton said:
25th Oct, 2010 at 05:19:54pm
Firstly. TD once calulated the optimum sise bore for IC tubing. But it was not a commonly available hose size, so most people use 50mm.. That was probably when most 'hot' turbo minis had 150hp, and only woodsie had a genuine 200... Oh how things change! |
25th Oct, 2010 at 05:47:00pm
No idea. I haven't exactly spent a lot of time working on the mini in the past year (or two)... I'm still muddling through Pauls efi posts trying to figure out what I want to do next... On 17th Nov, 2014 Tom Fenton said:
25th Oct, 2010 at 06:26:27pm
I find getting more than a 2" pipe past the selector tight. I trialled a custom 2 1/4 down pipe on the mock up engine in the car, and it fitted nicely. Perhaps the difference is the hardy spicer? 2 1/4 looks really big so I will have to increase the tail pipe to 2 3/4 at the very least. I think 3" would be a bit Barry like.
25th Oct, 2010 at 07:22:31pm
Humour a person who knows very little, but why would you need a tail pipe bigger than the rest of the system ?
25th Oct, 2010 at 09:19:39pm
nothing to do with performance, just the look. I currently have the Playmini 2" system which has a 2 1/2" tailpipe. It used to have a rolled end, but I cut it off as I didn't like the look, now it looks plain, but big, unlike some of that fancy shite that just does not look right on a mini. Maybe looks ok on a Saxo VTS. On 26th Oct, 2004 TurboDave16v said:
![]() 338 Posts Member #: 1911 Senior Member Swindon |
25th Oct, 2010 at 09:22:31pm
what would happen if you ran a 2/5" through to say a 1"3/4 or 2" back box? |
25th Oct, 2010 at 10:14:48pm
On the k16 set up I was using a 2.5" downpipe shape reduced to 2 just above potjoints,
i was trying to find figures for the engine to work out the best sized IC but so far have had no luck
