| Home > Technical Chat > Twin Carbs blow through (purely theoretical) | |||||||
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
25th Feb, 2005 at 05:39:17pm
I was just having a think about the extent people go to get maximum power, thinking about electronic ignition/squish, etc, etc. Fancy cylinder heads, etc, etc........ Bugger off, I'm getting there. |
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
25th Feb, 2005 at 08:42:10pm
crappy log manifold apparently designed intentionally to prevent charge robbing, which i'm guessing would be worse on forced induction a-series |
26th Feb, 2005 at 08:43:36pm
Crack on Stu, add it to the list of reasons not to finish the supercharger install.... On 17th Nov, 2014 Tom Fenton said:
27th Feb, 2005 at 12:55:20am
Yeah, the mini is going out with a full race NA engine at the moment, the supercharger conversion is a lot more intricate than I thought, and a lot more EXPENSIVE! Should bring home the bacon eventually.
Edited by Hedgemonkey on 27th Feb, 2005. Bugger off, I'm getting there. |
27th Feb, 2005 at 08:53:21pm
space....
AlexF |
1st Mar, 2005 at 06:34:08am
Sorry for giving yet another opposing opinion, Stu. If you look back some 2 or 3 decades there were never really good intake manifolds for twin SU?s, be it H, HS or HIF range. Those available usually need a lot of internal mods to make them worth your while. Currently Keith Calver is said to start supplying a specially developed manifold for twin SU?s.
1st Mar, 2005 at 09:56:10am
what about using one delorto (sp?), i.e off a lotus turbo?
Edited by Nic on 1st Mar, 2005. |
1st Mar, 2005 at 06:52:15pm
Jukka, I was merely talking about the benefits of using a straight shot from the jet to the inlet port with forced induction. I suppose this would be present in a blown Weber to a lesser degree. Obviously the high pressure air has a different pulse velocity, hence resonance/inertia, this would obviously make a normal Twin Manifold behave in a different way to how it was supposed to (different balance pipe required, etc, etc). It was just an idle thought I had and I thought about it and without resorting to the pen and diagrams (per usual) I figured that the gains were significant. I thought that there would be a serious imbalance of fuelling in a single SU engine (can anyone back this up, especially at high boosts?more so than N/A).
1st Mar, 2005 at 06:57:28pm
More headache... A wealth of jetting experience... To be honest not really worth the hassle, Dellorto carbs are more expensive to buy, you need to have a good source for jets AND you need to know how a change affects the function of the carb. Trust me on this, SU HIF44 is a great piece of carburation regardless of how mundane it looks. It is simple to setup, just one needle to file. With webers and dellortos there are literally thousands of jet combinations and these carbs are pretty sensitive to e.g. temp and humidity. Natural if you consider that they are basically fine instruments. Get them right and do they sing ! Get them wrong and they are pain in the arse. |
1st Mar, 2005 at 08:37:14pm
Hedgemonkey: -
1st Mar, 2005 at 10:04:11pm
thanks for that jukka, i often wondered if there would be much of a gain, but ill take your word for it and the su will be here to stay |
1st Mar, 2005 at 11:17:40pm
On 01/03/2005 20:37:14 evolotion said:
Hedgemonkey: - read this site with interest a few weeks ago... could be of use :cool: http://www.backyardmetalcasting.com/index.html Thanks, I've checked that a while ago, that was my mates inspiration for his foundry which he has. Bugger off, I'm getting there. |
2nd Mar, 2005 at 06:11:54am
There are of course benefits from Weber or Dellorto, one of which is the accelerator pump which basically means that you don?t need choke when starting from cold. Just press the pedal twice and the engine is running. It is a touch smoother in action, with properly executed linkange is is a joy to drive. Sometimes SU linkages are best described as sticky. Then there should be better throttle response, can?t really see that with my engine since the internals are not that light. Infinite tuneability is one criteria especially for race engines but does not really apply here. |
(per usual).
