Home > Help Needed / General Tech Chat > Does this look ok?
johnnysti
Member #: 2480
As ive been having problems starting the car, i have taken the starter motor off and had a look. The teeth on the teeth thing are slightly worn on one side. Is this ok or could it be a problem that could cause a starting issue? Alot of the time when trying to turn the engine over, the starter makes a weird whining noise like something spinning. Not sure what it is though. Thanks
feature=mhum
those teeth are fine buddy
my guess is starter pinion engagment needs a clean and oil
bosroamer
Member #: 1981
the Netherlands
Personally I thoroughly clean it but don't use oil.
If it is greasy it attracts sludge and you end up with the same problem
Edited by bosroamer on 26th Oct, 2010.
On 8th Aug, 2010 Brett said:
Carl worked my bottom end, cannot fault the workmanship its spot on, a good old chinwag too :)
fit a high torque starter, and bin that thing *wink*
