Home > Help Needed / General Tech Chat > How to fix plenum with no copper pipe?
tonton
Member #: 9069
Dumbarton
Hi, while inspecting bits and bobs for my build I noticed that the 1 inch cooper pipe that I have seen on other plenums is missing only a hole (the pipe that goes to the regulator). Anyone got good tips to fix, bear in mind I have no access to a welder? What size pipe is it?
Star Mag
Member #: 375
Leicestershire
Drill and tap it for a fitting. Somebody has Bodged a airline fitting in mine but it does the job. Better suited fittings are available.
Ron
A bit of 6mm copper pipe epoxied in will do the job.
Edited by wil_h on 27th Oct, 2010.
