Home > Introduce Yourself > hello!
broadie_50
Member #: 9160
Nottingham
Afternoon all, my names jamie I'm 19 with a couple of mini projects, I'm doing a vtec conversion but my priority is my 1380. I plan on a bizzarre setup for it, a supercharger for the road and a turbo for the track, hopefully ill be able to switch between the 2. So atm I'm just beefing up the block, sccr gearbox, forged pistons turbo ported head etc. I'm not looking for massive power, 125 from the supercharger and around 150 from the turbo would be more than enough. No doubt ill be on here posting for help a lot so I thought I'd give you a bit of a background. I'm also a coded welder so the fab side isn't a problem. I'm also more than happy to send my wage packet into the mini every month as I'm still at home *happy*
hi and welcome to TM
Hello and welcome. Suck or blow through?
broadie_50
Member #: 9160
Nottingham
Blow because I can use the intercooler for both then
broadie_50
Member #: 9160
Nottingham
Its looking a bit rough at the mo
Ben H
Member #: 184
Melton Mowbray, Pie Country
I guess that is one way to increase your post count.
Welcome, Ditch the supercharger, just run lower boost on the road, simples...
http://www.twin-turbo.co.uk
broadie_50
Member #: 9160
Nottingham
On my phone haha! Dodgy enter button.
Isn't there any advantage from running a supercharger over the turbo for mid range torque? I thought it would be better just for the turbo lag?
a warm welcome
with modern turbo's the lag isnt really an issue any more,
the only place a charger wins is it will provide boost down at 1-2k rpm, but personally i think this makes the car a bit undrivable in traffic,
Mini_the_minx
Member #: 9077
Cheshire
Hi
I'd be another blow through supercharger runner from Nottingham *hehe!*
All depends what you want the car for to be honest.
On 2nd Nov, 2010 wil_h said:
broadie_50
Member #: 9160
Nottingham
Just a weekend toy, don't need a car for work or anything. Then up the power for trackdays from time to time :) you in any club?
Mini_the_minx
Member #: 9077
Cheshire
Then I'd say go turbo if your wanting it for track use, more power available.
I was in NAM but we've drifted away from it now.
Ben H
Member #: 184
Have a read around there is lots of information about the pros and cons of turbos and superchargers. I would have a good read and look at other cars around to see what can be achieved.
This site is a little like an episode of QI. There is a lot of turbo info out there that is wrong, out of date or plain dangerous. We are here to try and correct a few things.
