Home > General Chat > NA 1380 Engine Valuation
dischub
Member #: 8143
London
I'm just curious as to what the engine would be worth in the mini?
Quick run down
ITG stub stack system filter
twin 1 1/2” SU carburetors
JKT (jacknight) full roller rockers
MED road comp big valve head ported and gas flowed
MED RS cam shaft
ARP head bolts
MED road comp block
Ni-Temped, X-drilled, wedged and backdrilled crank
Omega pistons
lightened rods
ARP rod bolts
Heavy duty duplex timing gear set
center main cap
Vandervell crank bearings
Gearbox
Straight cut close ratio gear set
Built with all new roller bearings and baulk rings
Center oil pick up pipe
Mini spares X-pin differential
Pre verto clutch assembly
MED ultra light billet backplate
MED ultra light billet flywheel
Orange diaphragm
Engine has covered about 20k since build
Would it best to sell gearbox separately? Same with Carbs?
Edited by dischub on 31st Oct, 2010.
quinton
Member #: 1911
If u sell the gearbox seperate I'll buy it.
it depends what condition its all in; for top money, I think you'd need to strip it down and demonstrate the condition. Dare i say it, it could be worth more in bits
Kean
Member #: 341
aka T2clubby
South Staffs
Always better to split, dibs on the bottom end if you do !
dischub
Member #: 8143
London
Cheer guys, it won't be soon, maybe in the next couple of months
philc
Member #: 1346
bromsgrove
i think it would be better if you split, i would be interested (price pending) in the crank & rods and possibly the arp bolts
kenny2
Member #: 5362
wexford in ireland
i've been in contact, hopefully be getting the full engine next year...
On 5th Jan, 2011 wolfie said:
If splitting I'd be interested in the filter setup.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
might take the carb setup if split
dischub
Member #: 8143
London
Right,
I'm planning to take the engine out in February if all goes well. Looks like it will be better to break the engine
Just wondering if these prices are okay?
£1000 for the short engine and head
£500 for the box
£200 for carbs and filter
Should the short engine include the flywhee setupl? Rockers? Will it be better selling head and short engine separate?
Just want to get an idea for prices for bits to see if breaking it will be worthwhile.
Edited by dischub on 24th Nov, 2010.
Kean
Member #: 341
aka T2clubby
South Staffs
I'm interested in the short engine, no head. Also the flywheel etc. Let me know how much you want buddy Drop me a pm if you like
Amp
Member #: 7856
I think I mentioned this before, but I'd be interested in the gearbox, I don't really need the x-pin as I have one but if you don't want to split it then I'll have to just sell mine! I'm not in a rush either so february is fine
boostjunkie
Member #: 9117
Northampton
Interested in the cross pin diff pm me :)
