| Home > Help Needed / General Tech Chat > OT, any plumbers on here? | |||||||
8th Nov, 2010 at 09:42:35pm
Just had a new combi boiler fitted in my loft and the water taps converted to mains pressure rather than the original boiler in the airing cupboard and header tank in the loft.
I seriously doubt it! |
8th Nov, 2010 at 09:45:34pm
This is a common problem with small is combi boilers.
8th Nov, 2010 at 09:47:37pm
Thats what I thought Jim, the bath taps feed pipe is 22mm, all others are 15mm.
Edited by paul wiginton on 8th Nov, 2010. I seriously doubt it! |
8th Nov, 2010 at 09:49:05pm
22mm feed on the bath?! what taps are those? Edited by Sprocket on 8th Nov, 2010. On 26th Oct, 2004 TurboDave16v said:
8th Nov, 2010 at 09:55:39pm
We have the same problem. I generally use the electric shower to help fill up the bath. Seems to help a bit. Edited by matty on 8th Nov, 2010. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
8th Nov, 2010 at 09:57:16pm
22mm is pretty large for a bath supply |
8th Nov, 2010 at 09:58:03pm
how close to the meter is your boiler? is there a lot of sharp 90deg bends in your gas run? A drop in working gas pressure will not help.
8th Nov, 2010 at 10:03:10pm
The house was built with 22mm pipes and bath taps are made for 22mm pipes. What do you lot have then? I seriously doubt it! |
8th Nov, 2010 at 10:06:06pm
back in the day bath taps were 22mm and other taps were 15mm, these days a lot of bath taps seem to be 15mm and other taps are those microbore threaded things that appeared with mixer taps. On 28th Aug, 2011 Kean said:
8th Nov, 2010 at 10:06:16pm
I always run 22mm for baths and mixer showers.
8th Nov, 2010 at 10:07:08pm
what is the boiler spec? it could well be down to the flow rate. most of our pipes are 15mm to the taps |
8th Nov, 2010 at 10:13:46pm
Ill have to find out the output. Its a Worcestershire boiler.
8th Nov, 2010 at 10:24:48pm
This is the boiler which my "friend" installs http://www.ferroli.co.uk/product_documenta.../F30_Manual.pdf
9th Nov, 2010 at 09:17:46pm
14.3l/min is a good flow rate for a combi |
9th Nov, 2010 at 10:10:46pm
Just found my info, its 12.6lt/min I seriously doubt it! |
10th Nov, 2010 at 09:56:39am
Paul, I had a look at the hot water feed from our boiler last night and it is in 15mm although i've not checked the spec. Only 22mm pipes are gas and mains water |
10th Nov, 2010 at 10:11:14am
Paul, maybe uoi should check that you are getting 12.6l/min, see if you can fill just over two buckets in a minute. Team www.sheepspeed.com Racing
10th Nov, 2010 at 11:17:39am
On 10th Nov, 2010 Jimster said:
Paul, maybe uoi should check that you are getting 12.6l/min, see if you can fill just over two buckets in a minute. I guess this would depend of the size of the buckets, eh? On 13th Jul, 2012 Ben H said:
10th Nov, 2010 at 01:44:43pm
u need to test the flow at the bath to check it, using a flow jug. Theres a gd chance it seems rubbish as the pressure is low but the flow is wat it suld be. ↲I am a plumber and its the same in 90 % of houses wen its converted to a combi↲Hope this helps
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
10th Nov, 2010 at 05:08:29pm
Cheers guys, Ill try the bucket idea and will talk to the installers when I can get hold of the buggers.
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
10th Nov, 2010 at 07:21:01pm
Try to get fatter so you'll need less water in the bath ... Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
10th Nov, 2010 at 07:58:01pm
On 10th Nov, 2010 Advantage said:
Try to get fatter so you'll need less water in the bath ... Dont need to be fat, I have an extraordinarily large penis which has that effect I seriously doubt it! |
10th Nov, 2010 at 08:07:24pm
On 10th Nov, 2010 apbellamy said:
I like an extraordinarily large penis
