Home > Help Needed / General Tech Chat > turbo inlet
sean g
Member #: 9184
lancashire bolton
what is the best inlet to use for a turbo 1275 or who can carry porting work out to inlarge the ports to the limit:) cheers
You'll probably have clearance issues with the exhaust manifold if you use any inlet other than the standard Turbo one.
Phil.
sean g
Member #: 9184
lancashire bolton
cheers mate have a side mounted exhaust and its a metro so have a bit of room to play
You will gain nothing by changing the inlet manifold.
Most gains are to be made by improvements to the head and better turbo efficiency.
i always thought the MG N/A was a better option,
although fitment is a pita, unless you us a mirage.....
Mr Austin flow tested both the Turbo & MG inlets, there was very little in it I believe.
tadge44
Member #: 2500
Buckinghamshire
So the effort I have put into fitting my nice Janspeed inlet is wasted ?
Looks nice though !
